An idea
Old Dec 21, 2009 | 08:12 AM
awebz's Avatar
Default An idea
What if I routed out the stock speaker holes in the rear of my car to fit 12s and wired an amp from the trunk?
My car is 240sx (s13 coupe)
Could it work, or horrible idea?
Old Dec 21, 2009 | 01:16 PM
Skittle's Avatar
You Can't Moderate Me.
Just buy a prefab box,stick the 12's in that..be happy,and not that ghetto.
R.I.P Pablo "Fathead" Garcia & Kevin "Slo_Si" Gonzalez Forever in our hearts.
Old Dec 21, 2009 | 01:52 PM
Kyleisme's Avatar
this is not fully correct info.. op if you do it right you can put some ib subs in there..
Old Dec 21, 2009 | 06:17 PM
the727kid's Avatar
If you wanted to go that route, fiberglassing a custom deck is a must, probably still would have to cut though.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Dec 22, 2009 | 06:35 AM
TJElite's Avatar
IMO, a proper IB sub setup is one of the best sounding you can put in a car. Note, I said proper. They are a ton of work to get right. You have to have a very solid baffle, and it must be completely sealed from front to back (no sound can leak through. I did my 5.1 lexus this way, and I ended up building a custom particle board / fiberglass rear deck, and used about 20 lbs. of clay to seal it from the trunk. Sounded awesome, though.
That sound quality is also subjective. A properly designed IB will be super accurate, and super linear, but they don't typically handle a lot of power, or get as loud as an enclosed system. If you are looking to 'pound' go with a box.
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Dec 23, 2009 | 05:11 AM
Skittle's Avatar
I agree,completely.
But taking the time to do it "right" is the key here,I'm sure you know alot of people don't do that...
Old Dec 23, 2009 | 06:08 AM
luke81's Avatar
hehe, these guys all make good points....IB does NOT mean hang a sub off the edge of the trunk lid, as i've seen a few times!
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
