need help installing wiring kit
Old Apr 12, 2009 | 05:47 AM
Mafiakiller's Avatar
Ballin Beretta
Default need help installing wiring kit
hey i got a 1996 chevy baretta and i am having trouble installing my power cable in my car (this has been always been my weakness when it comes to installing amp kits)...i got the rca's and remote ran through fine and the ground is ready to go..now all i need is the power cable installed...so is there anyone out there can help me and that has experience AND that doesn't do shit work.........thanks
Old Apr 12, 2009 | 06:08 AM
Paul's Avatar
Motha Fawking Baby Maker
not really sure what your asking for?....do you need help running it through the fire wall?
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Apr 12, 2009 | 09:21 PM
galacticmonkey's Avatar
coolest dude ever
If you cant get it through the firewall, just run it under the car.
Old Apr 13, 2009 | 01:54 AM
Paul's Avatar
run it right at the fender & the door..thats the best place
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Apr 13, 2009 | 06:11 AM
GradeA_TireFryer's Avatar
All American, rice eater!
you can always get it thru the fire wall - use factory gromet first - if not then drill you own hole, gromet and seal - done!
Old Apr 13, 2009 | 06:52 AM
ProvenPower's Avatar
If you still need this done give me a call at 813-988-3966. Ask for James.
WWW.PROVENPOWERTAMPA.COM
813-988-3966
ECU Socketing, Custom wiring Harnesses, Stereo, Alarms, Navigation, Electrical Troubleshooting, and More!!!
Old Apr 13, 2009 | 07:04 PM
Ballin Beretta
yeah pretty much...and the fire wall is pretty crowded...the fender is tricky..it just seems like there is no openings from inside the engine bay to the fender...also i have no drill to make a hole...anyone pm me a price to just help me out on running the power wire. thanks
Old Apr 15, 2009 | 09:13 AM
JDM Paulk's Avatar
Lose Control
remove that stupid black plastic piece near the brake
and its an automatic so then drill a hole through your clutch plate
or im sure theres a hole alreay on the wall
you might have to run it on the right side
Old Apr 15, 2009 | 06:49 PM
Ballin Beretta
what is gromet?
Old Apr 15, 2009 | 07:50 PM
1stGen7's Avatar
layin frame for life
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
