wiring problem
Old May 31, 2008 | 11:26 AM
eli's Avatar
eli
Default wiring problem
hey all.
i have a 15" treo tsx dual 4 ohm and a mmatts d300hc 2 ohm amp MMATS D300HC. i need to know how to wire these two together. pics would help a lot!
thanks
eli
Old May 31, 2008 | 12:06 PM
P057's Avatar
isuck
parallel the subs with themselves then connect to amp.
Since you have DVC subwoofers (2) and the amp can't go into 1ohm, you're screwed. They will only go down as low as 4ohms.
Planning before buying things could have prevented this. Now you're only going to get whatever power output the amp can put out at 4ohms.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old May 31, 2008 | 02:43 PM
eli's Avatar
eli
i only have one speaker, i ran it like this Subwoofer Wiring Diagrams . sounds pretty good, not as loud as i thought it would be but still pretty loud. i think u got confused when i said wire THESE together, i meant the sub and amp
Old May 31, 2008 | 03:24 PM
P057's Avatar
isuck
My reading comprehension isn't so good these days.
Glad you got that all situated.
Probably isn't as loud because it might not be tuned properly? Half the power gains are just from tuning the amp properly and checking things with multimeters to check and make sure everything is going the way it should.
Old Jun 3, 2008 | 10:17 AM
down_south_kustoms's Avatar
its a dual 4 sub run the let channel to the right and out to the amp if it a dual 2 you run the left neg to the right pos with one wire and run the bottom left pos and right neg to your amp .
Old Jun 3, 2008 | 10:20 AM
Rockford Fosgate® - Woofer WiringWizard
dont trust crutch there full of it
Old Jun 3, 2008 | 10:27 AM
sprjit22's Avatar
Rick James bitch
on the speaker wire positive to positive then to the positive on amp. Do the same on the negative. It is called parallel. It will give you a load of 2 ohms.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Jun 3, 2008 | 10:54 AM
eli's Avatar
eli
ive got a question, i ran the speaker like this Subwoofer Wiring Diagrams. i cant remember if i ran the wires from the amp going to the speaker to the same terminal instead of one on each terminal. the picture shows how i did it. should i have put either the neg or positive wire coming from the amp on the opposite side and have the jumper wire running on the other side?
Old Jun 5, 2008 | 03:56 PM
galacticmonkey's Avatar
coolest dude ever
What kind of box is it in?
