Tried to install radio
Old Mar 1, 2008 | 04:08 PM
CoRDiTe's Avatar
Not Mad
Default Tried to install radio
So I purchased a 98 passport and Went to install a radio in it, but the factory radio plugs are jacked up. They were cut and the previous radio was installed by splicing wires together without using a radio kit. I was wondering if I could cut the factory radio plugs off a civic/accord etc.. etc... and splice them to my 98 passport, would there be a problem or it would work ????
someone please help i dont want to splice wires together, I want to put it back to original form as if i bought it from the dealer brand new.... not rigged.
Old Mar 1, 2008 | 08:54 PM
HaZed's Avatar
No more Vtec!
hmmm...not sure...try checking the net for a wiring diagram....i found this site but they charge $13 for the diagram Car Stereo and Security Wiring Diagrams
Im sure if you surf around, you could prob find one for free....all you need to do is find out which wire is which and splice that with the radio wires...pm me if you need help...i live 1 min away
i just found this....98 honda passport stock wiring diagram...
Answer:
Right Front Spkr (-) Brown w/ Black Stripe
Right Front Spkr (+) Red w/ Green Stripe
Right Rear Spkr (-) Brown w/ White Stripe
Right Rear Spkr (+) Red w/ Yellow Stripe
Left Front Spkr (-) Gray w/ Black Stripe
Left Front Spkr (+) Blue w/ Green Stripe
Left Rear Spkr (-) Gray w/ White Stripe
Left Rear Spkr (+) Blue w/ Yellow Stripe
Ground Wire Black
+12 Volt Ignition Wire Yellow w/ Red Stripe
+12 Volt Battery Wire White w/ Yellow Stripe
hope that helps!
Old Mar 2, 2008 | 01:57 AM
CoRDiTe's Avatar
Not Mad
Answer:
Ground Wire Black
hope that helps!
wow. thanks so much for the help.... repped.....
Old Mar 2, 2008 | 04:30 AM
03AcuraCLTypeS's Avatar
P.I.M.P
if u want to do it truely right go to a stereo shop they usually sell the plug for radios, u can get the factory one and the one to plug into the factory one to wire to the radio, thats what i would do...all in all u might spend 40 bucks...that would put it bad to the way it origionally was the metra plug numbers are 70-7712 and 71-7712 any shop should have them in stock and if they dont carry metra they should be able to crossreferance to whoevers brand they carry
Big D
IT'S COMING!
Old Mar 2, 2008 | 06:39 PM
CoRDiTe's Avatar
Not Mad
thx for the info.... much appreshiated... (however you spell the word)
Old Mar 3, 2008 | 01:55 AM
P.I.M.P
no problem man if u need anything else pm me
Big D
IT'S COMING!
Old Mar 3, 2008 | 03:26 AM
CoRDiTe's Avatar
Not Mad
will do. thx
Old Mar 3, 2008 | 06:10 PM
CoRDiTe's Avatar
Not Mad
Answer:
Ground Wire Black
hope that helps!
Hey. Not sure why but when I looked at the wires in the passport mine are differnt color. Im making a assumption that maybe Depending on the month or quarter the car was built they changed the color of the wires ???
I can get the radio to turn on, all hooked up, but no sound comming though.. I even did a direct connect from the radio speaker wire to the speaker and still nothing...
Old Mar 3, 2008 | 09:27 PM
HaZed's Avatar
No more Vtec!
hmm...thats weird especially if you did the direct connect and nothing! id say check the fuses but if you have power to the radio, its prob not a blown fuse. Id also check the ground but same thing....you wouldnt get power if it was grounded! i would just mess with it....im lost with no advice sry man! ive hooked up tons of radios in cars but never heard this or have it happen to me before
Old Mar 3, 2008 | 09:46 PM
HaZed's Avatar
No more Vtec!
did some homework...a couple things...
1. your "chime" fuse may be blown which is located under you dash...its a small fuse that is sometimes used in volume control. It coulda blew by touching two wires together during the install.
2. try hooking up one speaker at a time. If one of the speaker grounds are bad, they will all not work....go through them and try it that way
3. there may be a factory amp. one of the grounds may be bad in that but to be honest, i dnt think the passport has a factory amp. just a option! check it out if the rest fails!
is the radio new or used? is it possible the internal radio amp is blown? can also happen by hooking up the wires wrong or by touching the head unit with power wire! good luck..pm me if u want help
