Hey so my 300/4 and 500/1 have an issue
Old Oct 8, 2007 | 06:39 PM
93ex's Avatar
Just Ledoux it!
Default Hey so my 300/4 and 500/1 have an issue
I think one or two of the allen screws are stripped. They are recessed so I cant dremel some slots in, and really tiny so I cant get many tools in. Any ideas?
Old Oct 8, 2007 | 07:14 PM
Notladstyle's Avatar
King of Ricers
Toby has a magic bit that will pull it out.
notladstyle.blogspot.com
Old Oct 8, 2007 | 08:15 PM
P057's Avatar
isuck
Kind of hard for him to just swing on by since he lives in Ft Myers.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Oct 8, 2007 | 08:19 PM
P057's Avatar
isuck
you can try this:
get some wd40 and lightly spray down a q-tip, grease up the walls of where the recessed screw is located. Try as best as possible to not get wd40 on the actual screw at all.
Get whatever allen key fits the best (or fit at one time) for the screw. Get a heat gun, let it get to optimal heating, and then quickly squeeze a decent size blob on the end of the allen key.
Put the key in, pushing down hard and into place the allen key into the screw, let it harden. Then while pushing down hard and slowly, turn it loose. You might need to try again with even more glue if the first time it breaks.
That's about the only idea I can give, sorry.
Old Oct 8, 2007 | 09:38 PM
the727kid's Avatar
I had this problem back in the day. Toby actually took care of it for me, but what he had to was use an extractor (can buy at lowes or walmart) and I could find any screws with that small of a head so we had to drill out the black piece so teh bigger head screw fit.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Oct 9, 2007 | 03:33 AM
93ex's Avatar
Just Ledoux it!
Originally Posted by P057
you can try this:
Yeah, thats all I could come up with, epoxying in an allen key, or at least getting the allen key to be the same size. I could just dremel down the surrounding plastic and then try to get into the screws.
Old Oct 9, 2007 | 06:32 AM
aaron1017's Avatar
is not Rotarded anymore!
The glue method works pretty good, have had to do it before!
LS1/T56 Heads Cam 1994 FD
Old Oct 9, 2007 | 11:52 AM
TJElite's Avatar
From memory, that screw won't come out through the access hole...I think that's why I had to drill it out on 727's amp. Other than that, its a simple job for an ezout.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
