tv static
Old Oct 6, 2007 | 09:20 PM
eli's Avatar
eli
Default tv static
hey guys. i have two visor tvs, for some reason the driver side tv is picking up static, the passenger side comes in perfect. anyone have this problem before or know why? i know possible reasons, because of power cords etc, is there anything i can buy to eliminate this interfence?
thanks
Old Oct 7, 2007 | 07:31 AM
Notladstyle's Avatar
King of Ricers
run cleaner wiring, solder the connection points, use the same ground for all the TVs.
I would check your video cable, its probably some crappy thin stuff with no shielding.
notladstyle.blogspot.com
Old Oct 7, 2007 | 12:17 PM
eli's Avatar
eli
so u think a better video cable will do the trick
Old Oct 7, 2007 | 04:51 PM
King of Ricers
twisted video cable and/or a signal booster and/or better ground points
Old Oct 8, 2007 | 06:11 AM
jriggs's Avatar
is better than you™
when i had headrest screens i ran into the same problem and it was a ground issue. make sure you have a real solid ground. if that doesn't work do everything notladstlye said and it'll probaly clear up
-james
