Need help with memory wire
Old Nov 19, 2006 | 08:51 PM
Grizzly0205's Avatar
**BoTtLeS aRe 4 BaBiEs**
Default Need help with memory wire
hey i am hooking up a cd player in my new car where the person before cut the harness off so now i have to go thru and find which wire is which. I found ever wire but the memory so all i can do now just have the memory spliced with the power just so it will turn on. Does any one know another way i can get the memory wire to work and actually let me keep my radio stations programmed after I turn the car off??
Old Nov 19, 2006 | 09:10 PM
TBSpyder's Avatar
Grab a multimeter and test for a constant, can't find one then go to the fuse box. If all else fails you can run a wire directly from your battery.
Old Nov 20, 2006 | 04:13 AM
o ok so the memory wire just needs to be hooked up 2 a hot wire that doesnt turn off??
Old Nov 20, 2006 | 04:30 AM
GradeA_TireFryer's Avatar
All American, rice eater!
check fuse under hood, these pop all the time!
Pirate Customs
Sound, Security & Style..... anything for your ride
Old Nov 20, 2006 | 01:17 PM
TIM TIM TIM's Avatar
could be worse
its just a 12v constant wire.. its not a smart wire or somthing
aim:because tim said
Old Nov 20, 2006 | 07:52 PM
SOTO's Avatar
what kind of car is it?
Old Nov 20, 2006 | 08:06 PM
92 integra this is my first integra i have had civics crxs nissans but no integras. I havent even seen the fuse box yet
Old Nov 21, 2006 | 11:16 AM
TBSpyder's Avatar
yup.
