Groud out issue...
I just got a Bazooka Tube and installed it into the back of my 95 Altima. When I close the trunk it gives me a loud woofing noise that sounds like ground noise. When the car is on (keys in the iggy) it does it, if they arn't in then no noise is emitting. Anyone got a clue? I'm still new to cars and doin ym best to get things done. Thanks!
It was good while it lasted. But, it was better in death.
First resand the ground location to metal and solder the crip that goes to ground.
Then check for loose connections including faulty RCA plugs.
Then put an inline choke on the positive power supply(can be purchased for 10/20$ I have a few laying around you can have if you come to the audio meet.)
ok cool thanks ill give that a shot!
The woofing or noise only happens when the trunk is closed when it is open the sound comes through clean.
16 guage wire, that shouldnt be a problem tho, the wiring harness for the bazooka uses 18 guage, plus the tube was hooked up in my buddies car using the same wiring with no problems plus a bazooka el is only 30 watts
it is runnign straight ot the battery at the positive feed
Originally Posted by NoTLaDStyle
if the positive is direct to battery I woul ddefinitely look at the ground for the problem - are you using any crimps in the wire? if you are try soldering the connections all the way through.
Like Dalton said...check the ground.
Toby
