quick question bout sub box
Old Jan 23, 2005 | 05:18 PM
mazda3vinnie's Avatar
Default quick question bout sub box
i recently purchased a sub box off of tr and it has been used it holds 3 12 subs there are some screw whole on top that go threw it will this make a difference with those small leaks on it, also if i put 3 subs in there that are 4 ohm dual voice coil whats the best way to hook them up to come out one terminole.. thanks for looking out
Old Jan 23, 2005 | 05:38 PM
kpr10is's Avatar
Maximaniac
Yes, leaks suck, throw some silicone or polyurethane or wood glue on there.
-Kevin
Old Jan 23, 2005 | 06:35 PM
TIM TIM TIM's Avatar
could be worse
thats the wiring i have, if you have questions just pm me or somthing.
aim:because tim said
Old Jan 23, 2005 | 06:49 PM
i have lanzars temporaily haha but will this work for any subs, and the will the extra neg and postive on the sub due i need to hook them up to the other side of my sub. whtmustang what subs u got, and what amp, does it hard
Old Jan 24, 2005 | 12:05 AM
kpr10is's Avatar
Maximaniac
nike, grammar owns you.
The only thing I can understand above to help you with is, yes that wiring diagram will work for any DVC 4 ohm subs
-Kevin
Old Jan 24, 2005 | 10:04 AM
i'm sayin you know how there is 2 negatives, and 2 positives
does only one side need to bee hooked up or do i need to run a wire from one side to the other.?
Old Jan 24, 2005 | 10:26 AM
93ex's Avatar
Just Ledoux it!
Wire it EXACTLY like the diagram :bbb:
Old Jan 24, 2005 | 11:17 AM
lol ight i'll geterdone thansk guys
