in need of expert help.
Old Dec 27, 2004 | 05:42 PM
nak1's Avatar
Default in need of expert help.
alright... so i have a strange problem.
when i turn my car on every once in awhile i get a strange high pitched whine... so first thing i think is bad ground... but here is the wierd part. It just gets louder and louder until it makes a loud pop in my front speakers. Im thinking if i had a bad ground it would be constant. Besides, it just started out of no where. Second thing is the front speakers seem to fade in and out. I will be driving along and the front speaks will get way louder and higher. But its temporary. Alright... so things im thinking are:
1. Maybe it is a bad ground (im going to reground the amps this week)
2. Maybe an impedance mismatch between my amp and front speakers.
any suggestions on what to check when im tearing apart the car this week?
TIA
Old Dec 27, 2004 | 05:48 PM
TBSpyder's Avatar
It could be a number of things. Bad amp. Bad deck. Grounded speaker. Etc. Etc. Etc. Do you have stock speakers? What kind of deck? What kind of amp?
Old Dec 27, 2004 | 07:09 PM
nak1's Avatar
clarion deck, Boston acoustics seperates, JL 300/4.
Old Dec 27, 2004 | 07:15 PM
TBSpyder's Avatar
My first guess would be the deck is bad...anykind of warranty on it?
Old Dec 27, 2004 | 07:16 PM
TIM TIM TIM's Avatar
could be worse
try the ground. I heard that if a power wire is to close to rca's it can cause that problem, never expirianced that though so i dont know how true it is.
aim:because tim said
Old Dec 27, 2004 | 08:44 PM
nak1's Avatar
imma have to check on the warranty. It would be the normaly clarion factory warranty. Thanks for the advice.
your right... power and sound wires dont mix. Its not that though. Im not an expert... but im no newb either. thanks for the try though.
Old Dec 28, 2004 | 12:17 PM
obie's Avatar
asian caucasian
I had the same problem years ago and it was a bad ground.
"I'm cooler than a polar bears toe nails."
Old Dec 28, 2004 | 02:47 PM
nak1's Avatar
amp ground?
Old Dec 28, 2004 | 02:50 PM
obie's Avatar
asian caucasian
yes the amp ground. I had a clarion headunit too
Old Dec 28, 2004 | 02:51 PM
TBSpyder's Avatar
Check to see if any of the speakers are grounded, could even be internally.
