Hmm Fuses...Does it really matter?
Old Nov 11, 2003 | 05:52 AM
Bumpin Expo's Avatar
Reppin' the 813
Exclamation Hmm Fuses...Does it really matter?
Well i blew a fuse today...An 80 amp fuse that came with my wiring kit. So i went to discounts and they only had fuses up to 60 amps, so would it b ok if i got this or would that restrict some power or something? THanks
Old Nov 11, 2003 | 11:58 AM
DANGERANGER's Avatar
Shop Bitch
It will not restrict power in any way. May just blow fuses if 60 is used.
Old Nov 11, 2003 | 02:33 PM
MDIFYTD's Avatar
Uber lurker
Are you talking about the fuse that is near your battery?
The reason I ask is because that fuse is there to protect the wire from the fuse to the amps from melting from too much current. More than likely what's happening is that your amps are drawing more than 80 amps and thus overloading that fuse.
So let us know what gauge wire you have and what kind of current draw your amp(s) produce and we can go from there.
Ill say i go by His and Al's thoery of "Your getting sprayed" Doesnt matter what it is. Grandma in the 1982 LTD is gettin the bottle.
Old Nov 12, 2003 | 01:29 AM
93ex's Avatar
Just Ledoux it!
and here I thought fusing restricted power by blowing if it was rated too low for the draw
