Help on wiring!
Old Oct 29, 2003 | 05:48 AM
Bumpin Expo's Avatar
Reppin' the 813
Exclamation Help on wiring!
Ok i have have 2 channel 200 watt lightning audio amp that i used to run my tweeters but i got some new infinity speakers so i want to run that amp on them. My problem is on one of the channels the posative doesnt work for some reason. I did have the amp running in one ohm by putting all the posatives into one posative and the negatives into one bridged but it got really hot because the amp isnt one ohm stable. The negative works on both chans but the posative on one doesnt work. Is there any way i can wire all 4 speakers to get a 2 ohm load or am i fuxed? Thanks guys
Old Oct 29, 2003 | 05:59 AM
93ex's Avatar
Just Ledoux it!
SOunds like you fubared an output on the amp
but for future refernace, the infinity comps shoudl have a 4 ohm total load, so running those in paralell shoudl giv eyou 2 ohm load, but you wont have any left right seperation.
Old Oct 29, 2003 | 06:01 AM
Reppin' the 813
i got the amp for free, the one channel has always been fubared. And yeah i kno they have a 4 ohm load but how would I wire the speakers to get a 2 ohm load? I wired all posatives to one chan and all negatives to the negative but thats a 1 ohm load. Any way i can get 2?
Old Oct 29, 2003 | 06:06 AM
Reppin' the 813
the x represents the messed up channel, could i like connect all the posatives to the posative that works and then 2 negatives to one then 2 to the other? would that give me 2 ohms?
93ex's Avatar
Just Ledoux it!
ar eyou running componets, or just like 5x7's and seperate tweeters?
Old Oct 29, 2003 | 06:11 AM
Reppin' the 813
just 4 5x7's and there are tweeters in the middle, i just want to run all 4 speakers to that amp but that 1 posative on the channel is fucked up! grr
Old Oct 29, 2003 | 06:18 AM
93ex's Avatar
Just Ledoux it!
well, this will give you a 4 ohm load
Which terminals you want ot hook it up to its up to you, I dont know your amp, but you can always try it on the good channel, and if that doesnt work, you can try using the negative form the bad channel and + fomr the good channel to bridge it..
Old Oct 29, 2003 | 10:37 AM
racingtheburg's Avatar
Pro 5oh
sooo thats how they do it awwww's in amasment
