two alternators?
Old Oct 27, 2003 | 09:16 AM
Miles's Avatar
It's a wooden pickle.
Default two alternators?
i remember seeing something about a kit being available... what would the pros/cons be of a dual alternator system? stock alt and lightweight batt for the car, upgraded alternator and optima batt for the system. or would it just be easier/better to upgrade to a single high amp alternator and optima battery?
Old Oct 27, 2003 | 10:20 AM
93ex's Avatar
Just Ledoux it!
well, dual alternators menas taking up more space in the engine bay..
and.. I dont see why youd need an upgraded high amp alt for the system alt.. seeing as it will still put out x amps of power, but without the drain from the electrical system.
I would do it like this. Batter, then High amp alt, and if it sitll isnt providing enough juice then look into a seocnd alternator
Old Oct 27, 2003 | 10:55 AM
rangcrx's Avatar
engine building &best
pro to 2nd ALt ,did this for a comp Crx,welded a 98 Bseries 110Amp Alt to a custom Ac bracket i made ((230$)) plus bought a BlueTop battery And wired everything from the system to this 2nd alt And always kept the 13.7Volts at PeakBass but in all just alot of work and money i would just go with a highAMp and 2batterys im sure your system is good and all but not needed for another ALtinator but if you wish to do this i can build you a bracket just let me no
i love AUTOZONE
Old Oct 27, 2003 | 11:02 AM
Jus Skott's Avatar
.arrow Jus Skott
teh pros to having 2 alts. is to power some amps.... I remember back in teh day when In came by an amp I liked alot phoenix gold 2250 came w/: 0 gauge wire, fuse block, and a second alt. jus for the amp. I loved that amp 2610 watts of pure bass'n evil..... wut to do wut to do..... Booom Booom Booom
TR Wondering WTH I moved from FL Member.
Back Then: A stupid Question was one that wasn't asked.
Today: A stupid question is one that wasn't Googled / Ixquicked first.
Old Oct 27, 2003 | 06:33 PM
tahoefresh's Avatar
a higher output alt would be a good way to go, from how i have had it explained the alt supplies the power to the batt regardless so the amp gets most of the power from the alt, getting a 2nd battery would just place more load on your alt to charge two batteries instead of one, getting a stronger batt is good but on the long run a stronger alt is nicer....
contact dominick@tds.com, he makes h.o. alts for anycar and can usually make them to fit in like the stock alt
Old Oct 27, 2003 | 10:21 PM
rangcrx's Avatar
a HighAmp alty does not have the cycles like a Reg alt it stays current for longer period of time,only thing is thay are about 200bucks more
i love AUTOZONE
