Audio Help please
i blew my battery terminal fuse i replaced it but now i have power going to the amp but it wont turn on is this a reszult of a blown amp its like there is power being supllied from the ground wire power wire they are all instaleed but no power to light up the light and it wont turn on thanks everyone
check your amp fuse and battery fuse again (your power wire may be pinched or be grounded somewhere), make sure u have a good, solid ground, make sure you have power on your rem wire. take a test light and see if u have power through your power wire from your battery and your rem wire from your radio. if so multi both and see if they read around 12v. reply what results you have after this...
"Lowriders are for boys who can't get it up..."
hehehe
hehehe
