injector size
Guest
Posts: n/a
injector size
4g63
small 16g
fuel pump
afc
dataloggin
all the needed boltons
20-24psi what injectors should i look into
between 7.8:1-8:1 CR btw
i was thinking 650cc would be good but i hear 550cc will be perfact
does injector size matter that much? (ie reight level and not over much that is .... i know under sized injectors suck.... dutie cycles etc is what im worried about)
small 16g
fuel pump
afc
dataloggin
good luck finding them without paying a fortune! Still looking for 550cc for my sr. Need that extra fuel baby!!
Drew
Drew
NEED PARTS WTB: Turbo Timer, TIAL 38MM+ WGATE, Race Manifold, etc
NEED a FPR installed!!
White 97' kouki RIP
Green 96 TURBO
White 97' kouki RIP
Green 96 TURBO
bwaaha, drew, your luck is bad, for you have a side load injector system, top loads are cheap as hell, you can get 550s for $200 or less all day....550's will do the trick, properly setup they are good till like 400 horsepower, which a small 16G cant make without spray
Poppa J. Smurf
Poppa J. Smurf
Originally posted by psifactor
I have rx7 550cc's that are great and I paid less than 200 for them ...which includes sending them away to be cleaned....
www.teamfc3s.org
www.rx7club.com
www.thepartstrader.com
dsm's use low impedence....I got a set of high impedence rx7 injectors and just took out the resistor pack to get the high impedence injectors to work.
High impedence are alot easier to find than low.
Heavy car with a 2.5L
