Starion intercooler
Starion intercooler
Any body know if the starion intercooler is good to use.
I know its a pretty nice size. Also do I need to up grade my injectors,or fuel rail, or fuel pump to when I put a turbo on the car. I allready have a B&m fuel pressure regulator. Any feed back would be great.
Thanks,
Joe
Thanks,
Joe
Guest
Posts: n/a
The Starion unit is an actual SpearCo core, so its a good one. It should support about 300hp which I'm assuming is more than your looking to make. If you have a Honda, then yes, you'll need to upgrade your fuel system when turbocharging.
starion fmic's suck, outdated smooth core design doesn't promote cooling as well as one w/ fins within the core or an extruded core...it'd probably work just fine, but its not the best option
Poppa J. Smurf
Poppa J. Smurf
