1995 Accord EX sedan Euro R Megan carbon
1995 Honda Accord Ex second owner
Asking $5,500 car is being sold as is has been sitting I garage started monthly could use a retune being it now has a straight 3 inch exhaust and i replaced the tps sensor.
I've had this car since 1997 I don't use it very much i'm getting close to 40 years old its time i find it a new home. call or text 321-507-0030 with any questions
Engine:
H22a with an Accord Euro R LSD Transmission from H motors
ACT light 12 pound Flywheel / Act extreme clutch
Gator stage 3 axles
Engine is Sleeved with Darton Sleeves
Wisco Pistons 11.5 compression
Eagle rods
Custom 4 inch cold air intake
Skunk 2 intake manifold
AEM fuel rail / AEM fuel pressure regulator
RC 550cc Injectors
Ported and polished head (325 cfm)
Crower stage 2 cams
Crower valve springs and retainers
Skunk 2 adjustable cam gears
5 angle valve job
70mm throttle body
4 inch custom intake
Hytech header
3 inch exhaust with a magna-flow muffler
Unorthodox pulleys Alt,PS,crank
Innovative engine mounts
High mount engine dampener
Carbon fiber spark plug cover
Koyo radiator
Exterior:
Custom Gun metal Metallic PPG Paint
Shaved door moldings
Shaved trunk key hole
VIS Carbon Fiber Hood / VIS Trunk / VIS Carbon grill
Mugen Lip Package Very Rare
Accord Euro R Carbon Grill
Projector HID headlights and clear corners
Engine management electronics:
MSD Ignition
Chipped ECU with chrome
Pioneer tv deck
Wide band gauge
Auto meter phantom Oil pressure gauge
Auto meter phantom volt gauge
Interior & Electronics:
Power Windows all work
OEM Floor mats
Custom paint to match bezel and center console
White gauges
Quick Release Steering wheel
with short hub
Skunk 2 shift knob
Grey shift boot
Suspension and Brakes:
18' 5 star wheels
12 inch front big brake kit 2 piece slotted rotors
Rear cross drilled rotors powder coated calipers
Stainless steel brake lines
Neuspeed springs
KYB AGX adjustable struts
[ATTACH=CONFIG]206642[/ATTACH]
[ATTACH=CONFIG]206656[/ATTACH]
[ATTACH=CONFIG]206659[/ATTACH]
[ATTACH=CONFIG]206643[/ATTACH][ATTACH=CONFIG]206644[/ATTACH]
[ATTACH=CONFIG]206657[/ATTACH][ATTACH=CONFIG]206658[/ATTACH]
[ATTACH=CONFIG]206645[/ATTACH][ATTACH=CONFIG]206646[/ATTACH][ATTACH=CONFIG]206647[/ATTACH][ATTACH=CONFIG]206648[/ATTACH][ATTACH=CONFIG]206649[/ATTACH][ATTACH=CONFIG]206650[/ATTACH][ATTACH=CONFIG]206651[/ATTACH][ATTACH=CONFIG]206652[/ATTACH][ATTACH=CONFIG]206653[/ATTACH][ATTACH=CONFIG]206654[/ATTACH][ATTACH=CONFIG]206655[/ATTACH][ATTACH=CONFIG]206656[/ATTACH]
Engine:
Gator stage 3 axles
Eagle rods
RC 550cc Injectors
Crower stage 2 cams
5 angle valve job
70mm throttle body
Hytech header
Koyo radiator
Exterior:
MSD Ignition
Pioneer tv deck
Wide band gauge
OEM Floor mats
White gauges
with short hub
Skunk 2 shift knob
Grey shift boot
18' 5 star wheels
Neuspeed springs
N0TSiCKiMiLL
For Sale/WTB Honda & Acura
Jan 26, 2010 08:27 AM
sleeveit
Aug 6, 2005 09:11 AM
