1994 Toyota Supra Twin Turbo 6-speed
Old Mar 30, 2017 | 07:11 PM
JZA80's Avatar
Default 1994 Toyota Supra Twin Turbo 6-speed
Garage kept, Cold A/C, New paint job, New front brakes/rotors, New iridium spark plugs, New rear tires, New racing seats, New interior carpet.
This is an original USDM Twin Turbo Supra, engine runs great, the Getrag 6 speed transmission shifts good, and original body has no no rust. Only 1 prior accident (fender bender) photos available
EXTRAS
-Factory seats included
-Factory carpet included
-OBDI ECU included
-OEM Toyota Service Manuals included
If you are interested...
TEXT or CALL me at 8I3-99O-96O7
Details:
Vehicle: 1994 Toyota Supra Turbo
Engine: 2JZGTE 3.0L DOHC Non-VVTI
Mileage: about 180,000
Transmission: 6-Speed Manual
Color: White (painted over the Renaissance Red original color)
Power achieved: Last dyno showed 399HP/430TQ @ 18 PSI averaging around 11.5 AFR
Top speed achieved: 150 mph (tested one time / scared the hell outta me)
Upgrades:
Meagan Stainless Downpipe 3" (no catalytic converter)
HKS Super Dragger 3.75" Exhaust System (from Downpipe BACK)
APEXi Super AFC NEO (Fuel Adjustment, Electronic)
AEM Wideband AFR sensor with gauge (Air Fuel Ratio 11.5 Tuned)
1997 OBD2 ECU (with corrected wiring, for richer fuel map) / Original OBD1 ECU also included
RPS Stage 3 Clutch with Sprung Hub 800ft/lb 3-Puck Racing Clutch (Done at Toyota of Tampa Bay)
XACT Streetlite lightenned Flywheel (Done at Toyota of Tampa Bay)
Blitz Electronic Boost Controller
Geniune SSR 19" 3 piece wheels, Made in Japan (could use powdercoat)
Rod Millen urethane front lip
HKS SSQ Blow Off Valve
Recaro racing seats with Bride seat rails, both are Genuine and Made in Japan
TRD Front Strut Brace
TEIN 1" Drop Springs + OEM struts
Viper Alarm System
Greddy 3 Row Intercooler
Greddy Turbo Timer
Brand new brakes (Hawk HPS Pads + Cryogeniclly Treated Slotted Rotors by SubZero)
What projects you will probably want to do. eventually..
-replace valve stem seals
-fix radio, speakers, power antenna
-power steering pump seals
-3rd gear grinds when shifting very fast (sychro)
-fix fuel gauge
-some speedometer/dash light bulbs are out
-carpet can be secured better
-backseat leather is worn
-window tint back hatch
https://tampa.craigslist.org/psc/cto/6053549555.html
Mysterious Driver
Jan 12, 2011 02:59 PM
ADAM
Jan 18, 2004 06:04 AM
