1993 240sx S13 Convertible with RB25DET Swap
Old Jun 10, 2016 | 04:26 PM
MSM2005's Avatar
Default 1993 240sx S13 Convertible with RB25DET Swap
Up for sale is my 240sx Convertible with RB25DET and 5 speed swap. The engine was imported by JDM Addiction in FL and swapped myself. It's been a long-term project of mine which never really got finished until just recently due to monetary reasons. Unfortunately, I have too many projects (automotive and general projects) and I need to simplify my life. Chassis has roughly 125k miles on it and RB Engine has roughly 55k. I always had a daily driver so the car was not driven much.
Car runs great. Recently, it was dyno tuned by Ash-Spec Performance. It put down roughly 390hp and 330tq on 16lbs of boost. In addition, a new Convertible Top & Window, Exhaust Gaskets, Z32 Fuel Filter, O2 Sensor, and NGK Spark Plugs were installed. The car is ready to be driven! Also, later down the road, someone can take it to the next level with bigger injectors and cams!
The Exterior has a few minor scratches/imperfections and a few little surface rust spots starting however the body is STRAIGHT with NO DINGS OR DENTS whatsoever. Overall, paint is good. If someone were to cut & buff it, spray some of the rear trim pieces again with flat black, the car would be refreshed and look amazing! Current State -- 8 out of 10
Interior has a cracked dash near the gauge cluster and rear stock seats are a little dated/dirty. All floor mats included. Carpet is good for the year of the car with a few imperfections. Only piece missing that I don't have is the convertible headliner plastic trim piece and sun visors were taken out. If someone removes the unnecessary old rear seats & rear trim pieces, puts some custom carpet in to cover the rear area, the overall appearance would look a lot cleaner. Or just put a nice painted roll bar/cage in! Current State - 7 out of 10
Exterior
Custom Chrysler Amber Fire color painted by trusted local body shop
Fenders have been rolled by body shop prior to painting
Non-Convertible S13 doors with Custom Seatbelt Relocation
BRAND NEW Stayfast Canvas Top, Head Liner, and Rear Window
Clear front Turn Signals
Clear style rear Tail Lights
Z32 300ZX TT REAR Wheels (4) all the way around (16" x 8.5") Powdercoated Black
Front Tires are Toyo Proxes T1R 245/45/ZR16 with little over 1/8" Thread
Rears Tires are mix match: 1 Toyo Proxes T1R 245/45/ZR16 with little over 1/8" Thread & 1 NEXEN N3000 245/45/ZR16 with 1/4" Thread
Engine & Exhaust
RB25DET Series 1 Engine & Transmission - Powdercoated Purple Valve Covers & Ceramic Coated Exhaust Manifold and Heatshield
Z2 300ZX TT Engine ECU with Custom AshSpec Dyno Tune Chip
Ignitor Chip with CPU Heat Sink
T3/T04E 60 Trim .63AR Turbo -- Ceramic Heat Coated Exhaust Housing
Walbro High-Pressure 255 ltr/hr Fuel Pump with Z32 300ZX TT Fuel Filter
Nissan Quest Higher Amp Alternator Upgrade
Greddy Intake Manifold -- Powdercoated Purple Vein
Q45 Large Throttle Body Upgrade
HKS Racing Blow-Off Valve Type 2
Custom FMIC Kit
Z32 300ZX TT MAF
APEXi Cone Filter
HKS Adjustable Internal Wastegate Actuator Kit
KOYO Upgraded Radiator with Electric Puller and Pusher Fans
CORE Performance RB25 Motor Mount Kit
Custom T3 Turbo Outlet Pipe with 3" V-Band Flange -- Ceramic Heat Coated & Additional O2 Sensor Bung
Custom 1 Piece 3" Downpipe & Testpipe -- Ceramic Heat Coated
APEXi GT Spec Exhaust - 3" inlet to 3.75" outlet
A/C has been removed
Drivetrain & Brakes
6 Puck Street Clutch with Upgraded Pressure Plate
1 Piece Custom Steel Drive Shaft
S14 Limited Slip Differential
5 Lug Conversion
Z32 300ZX TT Front Brakes (30mm Aluminum Edition)
Axxis Ultimate Brake Pads all around
SS Brake Lines all around
Russel Speed Bleeders all around
Custom Clutch Hard Line
Suspension
Megan Racing Street Adjustable Coilovers with Dampers
Megan Racing Adjustable TC Rods
Whiteline Adjustable Sway Bars
Metal Subframe Spacers Kit
Front Strut Tower Bar
Full Energy Suspension Chassis Bushing Kit Installed
Interior, Lighting, Electronics, & Gauges
S14 240sx Seats
HID H4 Headlights
Rear Trunk Battery Mount with Optima Red Top Battery
LS Automotive S13 Gauge Cluster Upgrade/Programming for RB25DET (Speed & RPM Accurate)
Defi D-Series Gauges (Boost, Oil Pressure, Water Temp) with Autometer Dash Cups
APEXi AVC-R Electronic Boost Controller
NISSAN Data Scan 1.4 PC program and USB Cable
Extra Parts Included
HKS Electronic Turbo Timer
Spare Ignitor Chip and Heat Sink
NISMO Cloth Shift Knob -- New
S13 Front Fenders -- Pair
Z32 300ZX NA Wheels -- Pair
RB25DET Engine Gasket Kit (Includes New OEM Head Gasket)
Additional S13 240sx Interior parts (Center Console, trim pieces, Etc.)
Stock S13 Convertible Sway Bars with Energy Suspension Bushings
1995 240sx OEM Factory Service Manual
1992 300zx OEM Factory Service Manual
RB25DET S1 Printed Out Service Manual
Boxes of Random S13 240sx Parts
Boxes of Random RB25DET Parts
Asking $8900 OBO - Clean Title
Car is in Melbourne, FL
Text or Call if interested at 321-243-4262
[ATTACH=CONFIG]206122[/ATTACH][ATTACH=CONFIG]206123[/ATTACH][ATTACH=CONFIG]206124[/ATTACH]
Click Photobucket Link below for more photos
Library Slideshow by MSM2005 | Photobucket
jtl260z
For Sale/WTB Nissan
7
Jun 16, 2012 07:23 AM
