FS/FT 1991 Mazda Miata 1.6 5spd
Old Jan 1, 2015 | 07:52 AM
DarkOctopus's Avatar
Default FS/FT 1991 Mazda Miata 1.6 5spd
So I am selling my 1991 Mazda Miata 1.6 5spd but will consider trades. The only trades I will consider are the following cars.
1981-1985 Mercedes Benz 300SD, 1980-1985 Mercedes Benz 300D (Turbo Diesel, no non Turbo Diesel cars), 1986-1987 Mercedes Benz 300SDL, and 1980-1985 Mercedes Benz 300CD Turbo Diesel.
I have a clean Title for my Miata and 3 Keys (2 Genuine Mazda)
I purchased my Miata back in April and have done the following:
New Parts Include:
New starter (lifetime warranty)
New Alternator (Lifetime warranty)
New valve cover gasket
New Cam Sensor Ring
New Sachs Organic Stage 1 Clutch
New LuK Flywheel
New Clutch Cable (Goodridge 25000-CLU, have the part just never installed yet)
New rear axle seals (Right and Left sides)
New Transmission Fuid (Within past 6 months) to Mazda Specs
New Rear Differential Fluid (Within Past 6 months) to Mazda Specs
New rear transmission seal
New rear main seal
New CAS Seal/Gasket
New NGK ZE-21 Blue Spark Plug Wires
New Front Upper Ball Joints
New Front Lower Ball Joints
New Front Tie Rod Ends
New NGK V-Power BKR5E-11 Copper Spark Plugs
New Rear Accelera Tires 75% Tread Remaining
New Front Radar RPX900 85 Tread Remaining
New Thermostat
New Thermostat Temp Sensor
New Coolant Temp Sensor
New Thermostat Sending Unit Sensor
New Red Silicone Coolant Hoses
New Heater Hoses
New 370CCA Battery from Advance Auto Parts (2 year free replacement)
Freshly cut front brake rotors with lifetime warranty ceramic brake pads
Freshly cut rear brake rotors with lifetime warranty ceramic brake pads.
New fuel filter
New Front Wheel Hubs/Bearings
14x6" Mazda Daisy Wheels with extended locking lugs. (Sprayed Gold, not blingy gold, but nice shade of gold)
New Part Upgrades/Modifications:
Tinted driver and passenger windows (darkest possible as per Florida Law)
New front/rear fully adjustable sway bar end links (Improved Racing)
New Front/Rear Polyurethane Sway Bar Bushings (Energy Suspensions)
New Front Upper Polyurethane Control Arm Bushings (Energy Suspensions)
New Front Lower Polyurethane Control Arm Bushings (Energy Suspensions)
DDM Works Elk Intake with Heat shield and Foam Filter.
Hood has Genuine Sparco Hood Pins (fully functional, not cheap ebay hood pins)
Polk Audio DXi651 6.5" Marine Certified 2 way Speakers.
Car has newer convertible top installed within past 3 years from previous owner.
MBS (Mandrel Bent Solutions) Spec Miata Exhaust (Catless) Mandrel Bending Solutions Home Page ... 02,/Detail
Also needs A/C Compressor and condesor.
Also has 2 tiny dents on drivers side of hood from rock falling from a truck. Will include extra touch up paint (exact Mazda Color match)
Has seats from 2004 MazdaSpeed Miata that are Red/Black.
This car is a 1991 but the engine is from a 1992 Mazda Eunos Roadster Long Nose Crank (non Federal Emmisions).
I have been very honest with all the work that I have done to the car and what needs to be done.
The car has a clean and clear title.
The car will be washed and waxed and you will get all 3 keys that I have. Will also include 2 brand new front upper ball joints and 2 brand new front inner tie rods.
Timing Belt and water pump done November 2013.
has 179800 miles.
Old Jan 2, 2015 | 10:37 PM
$2800 or trade
Old Jan 5, 2015 | 07:07 AM
$2700
Old Jan 5, 2015 | 08:50 PM
$2600
Old Jan 9, 2015 | 09:19 AM
$2500 bump
johnpaul parkerson
Jun 23, 2007 08:36 AM
vwrocxz19
Jun 7, 2006 09:25 PM
DemonCivic
Jan 9, 2006 03:49 PM
Lyonmt
Nov 19, 2005 05:12 PM
