93 CIVIC w/B20 swap, full suspension, etc. LIKE NEW!!!!
NEW PRICE.....ONLY $3,000!!!!!
1993 CIVIC, B20, New Interior, Suspension, etc. CHEAP!!!!!!
PICTURES ABOVE IN THE LINK!!!!!!!!^^^^^^^^^^^^^^^
Exterior:
NEW 1-Piece Black Housing Headlights with Amber Corners
Smoked Crystal Red/Clear Taillights
SI Sedan Polyurethane Rear Lip
Antenna Delete Block-Off Plate
Spoon Power Sideview Mirrors
JDM EG9 Ferio Rear Door Accent Panels
Rain-X Latitude Graphite Reinforced Wiper Blades
Interior:
Kenwood Excelon KDC-X493 Head Unit w/3 RCA Outputs, AUX/IN, USB/IN, BLUETOOTH/XM/HD
Kenwood KFC-1682ie 250 Watt 6 1/2" 3-Way Speakers in Front Doors and Rear Decklid
Hidden Antenna Conversion
Custom Full Black Interior w/Carbon Fiber Door Inserts
New Carpet
Black Suede w/Red Stitch Shifter Boot
Under The Hood:
2001 B20B Engine Swap with LS Transmission
Polyurethane B-Swap Engine Mounts
Moroso Stage 1 Oil Pan
Oil Pan Stud Kit
Oil Pickup Stud Kit
GSR Oil Pump Conversion
GSR Timing Belt Conversion
GSR Water Pump Conversion
Mishimoto Dual Core All Aluminum Radiator
New Thermostat
2 1/2" Full Exhaust w/Catalytic Converter Delete
New Oxygen Sensor
New Main Relay
New Distributor, Ignitor, Cap, Rotor, Wires, NGK Iridium Plugs
New Battery
New Alternator Belt w/New Spare
Short Ram Intake w/Cone Filter
Fuel Filter mounted Fuel Pressure Gauge
Full Engine Bay Wire Tuck
Custom Modified & Polished Valve Cover
New Fuel Pump
Synchromesh Transmission Fluid
Mobil 1 5W-30 Engine Oil and Filter
Dot 3 Brake Fluid Flush
Dot 3 Clutch System Flush
New Clutch Master Cylinder
9LB Lightweight Flywheel
Stage 2 XTD Clutch
New Throwout Bearing
New Pilot Bearing
Suspension:
Polyurethane Rear Trailing Arm bushings
Blackworks Racing Rear Lower Control Arms with Adjustable Swaybar Mounts
Rear Upper Control Arms Replaced
Polyurethane Front Lower Control Arm Bushings
Tein H-Tech Springs
Skunk2 Sport Shocks
Skunk2 Pro Series Plus Adjustable Front Upper Control Arms
Polyurethane Shock Bushings
All Bushings Replaced with Energy Suspension Polyurethane Units
Steering/Shifting:
Polyurethane Front and Rear Shifter Bushings
All Shifter and Steering Hardware Replaced w/Honda OEM bolts/gaskets/nuts/etc to Factory Specs
New Outer Tie Rods
New Manual Rack Conversion
Blackworks Racing Dual Bend Shifter
Blackworks Racing Weighted Shift Knob
4" Black Shifter Extension
Wheels/Tires:
Competition MB Wheels 15x7 20LBS/EACH
Dunlop Direzza DZ-101 205/50/15 w/Lifetime Rotate, Balance, and Flat Repair
Brakes:
New Front Calipers, Rotors, and Pads
Civic SI Rear Disk Brake Conversion with New Rotors and Pads
Civic SI Emergency Brake Cables
Exterior:
Interior:
New Carpet
Under The Hood:
Oil Pan Stud Kit
Oil Pickup Stud Kit
New Thermostat
New Oxygen Sensor
New Main Relay
New Battery
New Fuel Pump
Stage 2 XTD Clutch
New Pilot Bearing
Suspension:
Tein H-Tech Springs
Skunk2 Sport Shocks
Steering/Shifting:
New Outer Tie Rods
Wheels/Tires:
Brakes:
nextel_31
For Sale/WTB Honda & Acura
Sep 27, 2006 07:32 PM
