1993 S13 Convertible
I have a s13 vert with a lot of suspension mods 5 lug I got it bone stock from an older guy that used it as his daily very clean car everything works cold a/c. Unfortunately as you can see from the pictures it needs some cosmetic work. I was driving home from work one day got cut off by a stupid Florida driver in a SUV he stop short in front of me and I could not stop in time and bumped in the back of his car and then he continued to drive off. The car drove after wards but on my way home the car overheated and shut off and would not start again. I don’t have to time to fix it due to the fact that I am going to be moving in a couple weeks. So I need to sell it to get another car. My guess is it either a blown head gasket or needs a water pump. Cosmetically all it really need is a hood a front bumper and probably a hood latch. Would be a great platform for a swap or a awesome drop top drift car or you can fix it and use it as a daily driver like I did. The top is still in pretty good condition you can still see out of the rear window. Before accident car ran great was my daily driver and I drove it from Boynton to Boca everyday with not problems.
Send me a pm or a text in your interested and want to come look at the car 561-389-3830
Asking 2300 OBO
Here a list of everything done to the car majority of the parts are brand new
Emusa Front Tension Rods
Emusa Rear Upper Control Arms
Emusa Rear Traction Links
Emusa Rear Toe Links
JIC coil overs
F1 speed sway bars 30mm front 27mm rears
Nismo power braces
New front lower control arms with new ball joints
New inner and litter tie rod ends
All new sway bar end links and bushings
New rack and pinion boots
New polyurethane rack bushings
Full 5 lug swap (Attain front conversion hubs s14 rear hubs)
Z32 26mm Aluminum front brakes
Blue muteki tuner lug nuts
Tucked front fender harnesses (both sides)
Canadian DRL's
New Front Wheel Bearings
New alternator
New battery
Pioneer radio with USB plug
Pioneer interior speakers
Cold A/C
Clean interior Told by previous owner that front and rear seats where redone
Clean pair of coupe door panels
Extra set of window motors driver & pass.
Altima fans (not installed)
Extra pair of clean non cracked fender extension (not installed)
**!*!*!*!DOES NOT COME WITH 350Z WHEELS THEY ARE ALREADY SOLD*!*!*!*!*
Asking 2300 OBO
JIC coil overs
Nismo power braces
Canadian DRL's
New alternator
New battery
Cold A/C
You Aint Making Power Unless You Breaking Sh*t!!!!!
BOOST IS LIKE A VAGINA ONCE YOUR IN IT YOU DONT WANNA COME OUT!!!!!!!
crazygrk3
Dec 13, 2012 09:32 AM
Takamatsu
May 6, 2010 07:24 AM
