1993 nissan 240sx hatchback $2000 need gone asap quick sale
Old Sep 26, 2013 | 04:58 AM
s13x42's Avatar
Default 1993 nissan 240sx hatchback $2000 need gone asap quick sale
Ok so I would like to sell this. A car I want just popped online. It runs good. No missing at idle. Now this is the dilemma. I have a clear title no problems with it except the seller name is filled out due to a sale that didnt go through right. I either have to get a new title from the dmv and wait 2 weeks or try to get an affidavit. I am gonna talk to dmv monday and find out my options. I could work out a deal with someone until i get the title. Now the car does have its faults. It needs bodywork. Not that bad but a little filler would be nice. The coilovers are popped thought. They can be rebuilt if needed. The dash is cracked like a usual 240. The rack leaks alittle bit every now and then. Now the big problem I have is a little play in the steering. I think it is just the rack is worn. Now on the good side the AC blows nice and cold. The KA starts everytime. I removed the emssions and butterfly valves so it flows great. It holds a good oil pressure and vacuum. It has never let me down. 727 452 0272 . Im looking for 2000 firm. i cant go no lower. No lowballing or ill ignore you. I need it gone today! this is a steal for a good running s-chassis with cold a/c which is a must in florida. I can show the car all day today.
Pros:
Rebuilt ka24de
Felpro Headgasket
Felpro headbolts
New water pump
New coolant temp sensor
Blue leds in cluster
Water temp, oil pressure, volt and vacuum gauges
aftermarket tail lights
Custom pignose lip
momo steering wheel
leather s14 seats
new outer tie rods
quest alternator
optima red top battery
aluminum sr radiator
rustless hatch
crackfree windshield
6 bolt j30 vlsd
aftermarket wheels 15x6 in front 17x7 in rear
polyurethane steering rack bushings
Taurus efan ran on relay setup to switch
Tucked harness
s14 seatbelts
ac works perfectly just had it fixed.
180sx front brakes
all new brake pads all around
walbro 255
new 300z fuel filter
cusco camber plates
front strut bar
new waterpump
new starter
ACT stage 1 clutch
Full 2 1/2 inch mandrel bent exhaust with resonator. Sounds nice.
intake pipe
Cons:
Slight play in steering.
Rack leaks sometimes
Tranny rear seal leaks
needs body work
passenger fender is bad
has buddyclub coilovers but they are blown
Carpet sucks.
[ATTACH=CONFIG]201638[/ATTACH][ATTACH=CONFIG]201639[/ATTACH]
Fresco1310
For Sale/WTB Honda & Acura
Jan 18, 2012 11:53 AM
dandrifts13
Apr 27, 2010 04:42 PM
