1jz s13 240sx hb
Old Sep 22, 2013 | 07:20 AM
lmalfatti's Avatar
Thumbs up 1jz s13 240sx hb
1JZ S13 240SX HB US$7999
-1993 Nissan 240sx Hatchback
-1JZ-GTE 2.5L Twin Turbo (350hp @8lbs)
-5 Speed Manual Transmission (remanufactured R154).
-Coil pack and spark plugs replaced.
-Mobil 1 10w/20 full synthetic oil. Changed every 3k miles.
-Autophonics 255lph high performance fuel pump.
-Air Conditioner (Needs Freon)
-Power Steering
-Functional Speedometer
-Functional Tachometer
-Genuine BRIDE Low Max driver seat
Drivetrain:
-Hybrid Driveshaft for R154 transmission.
-Hybrid Motor mount/Trans mount using Megan Racing hard rubber (No vibrations).
-New rack and pinion with polyurethane bushing kit.
-1996 rebuilt J30 LSD differential with Mobil 1 full synthetic gear oil.
-New R154 short throw shifter (rare).
Cooling:
-Megan Racing 3 core performance full aluminum radiator.
-Flex-a-lite 12" dual electric fan (blowing over 2k cfm per fan).
-Toyota genuine 2JZ-GTE upgraded water pump.
-Toyota genuine pulley upgraded.
-Toyota genuine belts upgraded.
-CX Racing front mount intercooler with 3" pipe.
Suspension/Braking:
-Ksport Slide Kontrol Drift Coilovers
-Megan Racing front/rear sway bar end link (polyurethane).
-Motti's Garage Front/Rear sway bar 30mm front/28mm rear.
-Front tension rod.
-Front/Rear lower control arm kit, Rear upper control arm kit.
-Rear traction kit, Rear toe arm kit.
-Suspension fully adjustable.
-R32 front Calipers.
-R32 zinc slotted and drilled front brake rotors with new ceramic pads, new front braided steel brake lines.
-S14 zinc drilled rear rotors with new ceramic pads.
-Wilwood proportion valve.
-Mobil 1 full synthetic dot 4 brake fluid.
Wheels/Tires:
-All the way around 18x9.5 +25 XXR 522 (with some curb harsh on the rear).
-225/40/18
-I've got all 4 18x9.5+25 XXR522
CONS: It needs new front passenger hub (5x114.3)
It needs AC freon
It needs Aligment
It needs brake master cyl.
US$ 7,999.00 CASH / OBO
NO TRADES - NO TRADES - NO TRADES - NO TRADES
NO JOYRIDE - NO JOYRIDE - NO JOYRIDE - NO JOYRIDE
NO TIRE KICKERS - NO TIRE KICKERS - NO TIRE KICKERS
MONEY TALKS - BS WALKS / Simply as that
Call or Text (404) 380 56 47 let me know if you need more pics, I'll text it to you.
1JZ S13 240SX HB
Old Sep 23, 2013 | 03:20 AM
4DRDANesto's Avatar
Done right,, bump glws
Hybrid Motorsports
Hybrid Motorsports
14
Sep 20, 2013 05:31 AM
flyspyder55
For Sale/WTB Toyota
Jul 7, 2013 12:46 AM
Mr.Steve-O
Jan 21, 2012 07:07 PM
