2 Turbos
Old Jan 4, 2013 | 11:29 AM
70-yenko-nova's Avatar
Default 2 Turbos
The Holset is in missouri for right now and the 60 trim is in cape coral.
Holset hx35w 7 blades t3 twin scroll the shaft play is normal for this unit no smoke. It comes with an internal wastegate block off flange and copper gasket for the internal wastegate block off flange. The turbo is very clean has no rust which is surprising cuz most of them i see look terrible. I can also safety wire the internal wastegate closed if you would like also.Lastly is the massive filter that will go directly over the intake.. because I dont run open turbos anymore (learned hard way)
http://www.aemintakes.com/store/product.aspx?Prod=21-2059DK
^^^ That is the filter
All of that though for $500
~~~~~~The garret was used for 6 dyno runs on an acura integra with a k20 swapped motor (2.0L vtec for non honda people) and it made over 360whp from what im remembering.
$450 for the garret 60trim.
The last picture is of the garret all the others are the HX35
the gasket and flange that i have are linked here
http://www.mandrel-bends.com/catalog/flanges-gaskets-36/turbo-flanges-62/holset-hx35-turbo-outlet-flange-wg-blocked-1-2-mild-steel-2298.html
http://www.mandrel-bends.com/catalog/flanges-gaskets-36/copper-gaskets-216/turbo-gaskets-218/hx35-turbo-outlet-gasket-wg-blocked-0-043-copper-2516.html
Cant Wait For TX2K13!!!
http://www.youtube.com/user/godhand101
Got More Parts Then Jesus
Old Jan 4, 2013 | 03:19 PM
bump....
nasdstang
Feb 9, 2006 04:35 PM
Scott
Feb 11, 2005 04:40 PM
