WTT S13: Z32 Brakes - Solid bushings - Alum Drive Shaft - RB/Z33 Trans mods - For S14
Old Nov 13, 2012 | 08:48 AM
M374llic4's Avatar
word
Default WTT S13: Z32 Brakes - Solid bushings - Alum Drive Shaft - RB/Z33 Trans mods - For S14
Hello everyone, I really miss having my S14 and would like another one. If anyone has one they are wanting to trade for a decently modded S13 that is a perfect candidate for a motor swap, let me know! Not looking to sell outright as it is my only car at the moment and I cant have downtime.
S14 must be manual, and prefer working AC. Nothing busted up and drifted and ragged out to all hell. Please have pics with trade offers as well!
1991 S13 240sx DOHC.
Mods:
-SPL Tension Rods
-Polyurethane suspension bushings with custom-installed grease fittings
-KYB GR2 Shocks
-15x7 wheels
-SPL solid aluminum rear subframe mounts
-Z32 300zx turbo rotors and aluminum front calipers, new stock rear calipers with Infiniti Q45 rotors
and Z31 300zx mounting brackets, Z31 300zx brake master cylinder, Hawk HP Plus pads, stainless
braided lines, SPL brake cooling panels
-One piece aluminum driveshaft
-Steering rack converted to manual steering, Polyurethane steering rack bushings,
solid metallic steering column bushing
-Nismo engine and transmission mounts
-Chromalloy RB20 lightweight flywheel with Exedy 350Z clutch, stainless braided
clutch line
-SR radiator, electric fan conversion, new coolant hoses
-Ebay intake and header, Megan Racing Type II exhaust, timing advanced +3 degrees running 93 octane,
power steering delete pulley setup
-S14 240SX Seats, converted manual seatbelts
Maintenance:
-Timing chain tensioner fix, new fuel pump and filters, NGK plugs and wires, new distributor cap
and rotor, Redline MT90 trans lube, changed rear diff lube, flushed cooling system, new coolant overflow
bottle, new headlight stalk, aftermarket replacement carpet, new clutch slave and master cylinders,
new valve cover gaskets, new tie rods, tie rod ends, tie rod boots, new front ball joints
Current problems:
-Air Conditioning doesn't turn on. Everything is there and hooked up, but the compressor just does not kick on.
-Oil leak from engine front cover, needs to be pulled and resealed. Not enough to make oil level drop much,
but leaves stains under the front of the car when parked.
-Valve stem seal is bad. Car sometimes smokes a bit when you first go from a stop light, but that is the only time.
The E-Fan's turn on wire came disconnected and my buddy at a shop hooked it back up for me quickly because it was hot out and I had my son, so the wire is jumped in to the Engine Control. I am guessing because of the additional power being drawn is what is making it act a bit weird while idling and when you turn the car off.
94' Sentra, 65' Mustang, 89' 240 Hatch, 90' 240 Hatch, 90' CA18 Coupe, 89' Sexy Gold Hatch, 99' Sentra (SR20), 95' s14 , 93' BMW 325is, 91' SR'd 240, 95' s14, 90' KA24DE-R, 89' KA24E-T (soon to be 500hp) (only a few of the cars I have owned, ugh..)
[Thunderfury, Blessed Blade of the Windseeker]
Old Nov 14, 2012 | 04:51 AM
M374llic4's Avatar
word
up
Old Nov 14, 2012 | 10:39 AM
M374llic4's Avatar
word
up
Old Nov 15, 2012 | 10:21 AM
M374llic4's Avatar
word
up
Old Nov 21, 2012 | 10:27 AM
M374llic4's Avatar
word
up
Old Nov 28, 2012 | 05:58 PM
M374llic4's Avatar
word
up
Old Nov 28, 2012 | 10:50 PM
Minimechanic's Avatar
EII Autowerkz
Trade for an sr hatch
Old Dec 3, 2012 | 04:51 AM
M374llic4's Avatar
word
up
Old Dec 4, 2012 | 08:14 PM
a64nova's Avatar
shoot me a txt or call at 727-560-0332
thanks james
CAN YOU DIG IT
Old Dec 7, 2012 | 05:55 AM
M374llic4's Avatar
word
up
M374llic4
Dec 11, 2012 10:32 AM
s13silverbullet
For Sale/WTB Nissan
5
Jan 25, 2011 11:40 AM
Zenki Sean
For Sale/WTB Nissan
8
Aug 24, 2009 03:15 PM
4DRintegraT
For Sale/WTB GM - Buick, Cadillac, Chevrolet, Pontiac, Saturn
Jul 22, 2009 02:32 PM
