240sx 1998 built sr20 kouki - $10500 (orlando)
Old Oct 18, 2012 | 06:32 AM
rondaom's Avatar
Default 240sx 1998 built sr20 kouki - $10500 (orlando)
1998 clean title 240sx built s14sr20 motor. Blitx twin plate clutch. full bltz nurspec cat back, tein coilovers. 17 inch 5zigen fno1rc 17x9 17x10.5. Motor built by MAZWORKS WITH ALL THE RECEIPTS. Car was mostly put together by CARISMA very clean and fast. Very nice paint job super clean and fast ride call oamr 407-484-8664.new oil pump - S14, SR20
CP Piston, 86.5mm 9.0:1, SR20DET
Manley H-beam rods SR20DET
Mazworx SR20 stud kit
Calico coated ACL thrust bearing Set, Nissan SR20DET
Calico coated ACL H-series rod bearing set, 17mm wide, Nissan SR20DET with 5 oiling holes
Clean and R/R Oil ports
Oil groove machining SR20
Resize line bore
Bore and hone w/ torque plate
check, polish, balance crank
resurface block and oil pump (together)
Assemble short block, provide spec sheet
Tomei Adjustable cam gear
Supertech dual valve springs, SR20, 95lb seat
Supertech titanium retainers, SR20
Supertech inner spring locator, 7mm valve, SR20
Supertech inner spring locator, 6mm valve, SR20
Supertech exhaust valve stem seal, SR20DET
Supertech intake valve stem seal, SR20DET
Mazworx SR20 head stud kit
Walbro Setup kit S14
Walbro 255HP fuel pump
Apex metal headgasket, SR20, 87, 1.1mm
Water pump, S14/ S15, SR20
Rocker
Rocker guide
Aseemble longblock, degree cams
Timing chain guide, fixed, SR20
Timing chain guide, adjustable, SR20
Tomei HLA type intake camshaft 260, 12mm lift, S14/ S15
Mazworx SR20 bolt kit, fixed timing chain guide
Nismo pilot roller bearing
Other goodies either installed by us or by Carisma -- total invoice $2893.85
Tein Coilovers
z32 Aluminum front brake calipers
stainless steel brake lines
New DTC gear
Battery relocated
replace TPS
replace SR20DET MAF
new front right and left lower control arm for tighter turn radius
blitz twin plate clutch
blitz radiator http://[IMG]http://i98.photobucket.c....jpg[/IMG]
Old Oct 19, 2012 | 03:17 PM
Ride_on_luck's Avatar
link doesn't work
turbojohnj
May 29, 2011 11:47 AM
boostintt
Nov 13, 2008 08:40 PM
