F/S Only: Built Long Block for Turbo.. Ferrea, Weisco, ACL, Supertech, Blox...
Old Aug 10, 2012 | 03:47 PM
jordank's Avatar
Default F/S Only: Built Long Block for Turbo.. Ferrea, Weisco, ACL, Supertech, Blox...
Bottom End
B18a1 Block Guarded (Golden Eagle), Weisco 9.0:1 pistons, Eagle H beam Rods, Arp Rod Bolts, ACL Bearings, Micropolished Crank, All New Seals, Felpro Head Gasket, Golden Eagle Sandwhich plate with feed line, Light weight flywheel. Tapped Oil pan, all new gaskets!
Top End
B16 Head, Type R cams, Type R valve cover (tapped for breather box), Machined by LHT, Ferrea 1mm oversize dished face valves, Supertech Bronze Valve Guides, New Valve Guide seals, Supertech dual valve springs, Supertech Retainers, Arp head studs, Brand New Timing Belt, Skunk 2 Tuner Series Cam Gears (Red), Eldebrock Intake Manifold Gasket, Blox Version 3 Intake Manifold, Blox 68mm throttle body, Blox throttle body gasket, Blox Billet Cam Seal (Purple), 0bd1 dohc vtec dizzy, New exhaust manifold gasket. By the way it's all new!
The price is $3000... if you need anymore info just pm me!
Old Aug 11, 2012 | 04:47 AM
jordank's Avatar
Old Aug 11, 2012 | 10:06 PM
jordank's Avatar
Old Aug 12, 2012 | 06:57 PM
jordank's Avatar
Old Aug 12, 2012 | 07:05 PM
SloCivic's Avatar
ttt nice build
Old Aug 13, 2012 | 10:34 AM
jordank's Avatar
Old Aug 14, 2012 | 01:57 PM
jordank's Avatar
Old Aug 15, 2012 | 07:53 PM
jordank's Avatar
Old Aug 18, 2012 | 07:57 AM
jordank's Avatar
Old Aug 18, 2012 | 06:32 PM
01LatinVizionGSR's Avatar
I'm interested in the block if you decide to part out lmk pm if you have a price.
