Fs- Black 2000 civic Si } Gsr + BOOST!
For sale 2000 civic si, was made exact date Dec 26 1999. purchased 3yrs ago with 117k, car has 138k on body.
For sale only, will not trade unless it is well worth it and has A/C, car is rarely driven. has a new front end on it, clean title and has A/C just recharged recently. Moving onto better things and the car must go, everything electronic on the car works, sunroof, cruise control, everything a/c heat etc... below i will list everything that was done and changed to the car. Low ballers will be simply IGNORED, no time for BS. Recently ran 13.4 in 1/4 on 10psi with full interioE and STREET TIRES, tuned for 14psi so can easily break 12's. Block can handle more just need bigger injectors and turn up the boost, tho it is already dynotuned.
Askin 7.5k. Below is why, and anyone serious can pm or call
if you view bumper up! 813-900-3413
New rack & pinion
master cylinder
new opads front & rear
new axles
walbro 255
new windows regulator new
new alt.
new battery
new hood
new headlights
new fenders
new bumper
new oem si lip
new ac belt
freshly recharged a/c
all new bulbs throughout car
oem si radio
sony speakers
type-r shift boot w/ s2k shift knob
skunk2 short shifter
all new poly shift bushing.
working cruise control
suspension-
Tokico blues
nuespeed race springs
fully adj. camber kit front and rear
si rims 80% tread on faulken zien 502's
100% tread in rear
new outer tie rods
new ball joints
Motor-
freshly built, hone/deck/ 1500 miles on motor
newly tuned by alpha tuned for 14psi over 300hp
b18c1 81mm bore, wiseco flat top
eagle rods
clevite bearings
scat rod bolts
.0015-0017 rod bearing clearance on all rods
.002 across crank
p28 chipped & socketed w/ data log by neil sutton himself.
bar and plate 3 core half sized radiator. w/ slim fan
solid upper mount
all torque mounts are there
tranny and rear mount are new
Head-
type-r head
ctr intake cam
itr exhaust cam
ti retainers.
type-r rep. intake manifold
vision red cam gears
all new seals & gaskets
new dizzy
new plug wires lifetime warranty.
brk 711 plugs
gapped at .032
edelbrock IM gasket
160 deg. thermostat
fpr with gauge
Str cam seals
new temp sensor
Turbo kit-
450 dsm injectors w/ resistor box, recently serviced before tune have flow chart.
omni 4 bar map sensor
drag manfiold
38mm wastegate
Cx racing 60 trim freshly rebuilt w/ garrett internal.
custom oil return line
custom oil feed line
greddy intercooler and piping
greddy turbo timer
greddy type-s bov
custom 2.5in downpipe
greddy evo 2 exhaust.
Transmission-
b16 tranny with phanton slip LSD
cryo treated gears
carbon coated gears
Bads-
since front end is new needs paint. for the right price will paint front end
carpet needs a little cleaning
si seats have little fade from sun
center console is a bit worn
passenger side door has very small dent
rear bumper has little crack
car vibrates a little because of SOLID motor mounts, holds all the torque for the motor though.
Couple vids...SC s2k and h22 lude..
New rack & pinion
master cylinder
new axles
walbro 255
new alt.
new battery
new hood
new headlights
new fenders
new bumper
new oem si lip
new ac belt
oem si radio
sony speakers
suspension-
Tokico blues
100% tread in rear
new outer tie rods
new ball joints
Motor-
eagle rods
clevite bearings
scat rod bolts
.002 across crank
solid upper mount
Head-
type-r head
ctr intake cam
itr exhaust cam
ti retainers.
new dizzy
brk 711 plugs
gapped at .032
edelbrock IM gasket
160 deg. thermostat
fpr with gauge
Str cam seals
new temp sensor
Turbo kit-
drag manfiold
38mm wastegate
greddy turbo timer
greddy type-s bov
Transmission-
cryo treated gears
carbon coated gears
Bads-
bump for my old si...
"sweet n' low"
"fucking classy <3"
2000 EM1 GSR ON BOOST **TRADED**
1993 EG HATCH TYPE R ALL MOTOR**TRADED**
1995 JDM FRONT DC4 **TRADED**
1995 DC2 BUILT **TOTALLED R.I.P**
1998 DB8 **TRADED**
1996 LS INTEGRA **TRADED**
"fucking classy <3"
1998 DB8 **TRADED**
it is for sure bro i can still see the spray paint on the grillk i did day i got it. lol.
"sweet n' low"
"fucking classy <3"
1998 DB8 **TRADED**
"fucking classy <3"
1998 DB8 **TRADED**
