FS: 1995 Civic (EG) Coupe
1995 Civic Coupe (EG), only had it for a few weeks, not even registered yet. Picked it up from someone as is.
all motor work was done at Kissimmee cylinder head corp
rebuilt B18A1 (will get exact miles on engine)
B18B1 head w/ ITR dual springs & retainers
B18B1 cams
resurfaced head & decked block
block has brand new aluminum pistons 82.5mm bore, stock compression
brand new rod & main bearings
balanced & polished crankshaft
block guard
new oil pump (P72)
all seals & gaskets are brand new (entire motor)
2.5" exhaust w/ vibrant muffler
stock header
B16A short gear ratio transmission
hasport tranny mount
ACT light weight flywheel
Stage 2 clutch
CHIPPED P28 ecu
i-Flik 15x6 wheels
GSR front brakes
Rear disc conversion
sleeve coilovers
front & rear camber kit
rear lower control arms
Lower rear tie bar
Ebay spoon side mirrors
amber corners
Fog lights w/ switch
EK side skirts
Mugen style front LIP
6k HIDs
LS front seats, stock rear seats
Quick release steering wheel
EX cluster
pioneer CD player
skunk2 short shifter
GSR shift knob
BAD:
roof & trunk is faded, dings & scratches here & there
driver window regulator is bad (tried fixing it, but you have to help it up)
driver door panel is for a car w/ power (the car has manual locks & windows)
will need tires & alignment (also check tie-rod)
will need the rod/knobs for the climate control
just needs some TLC overall
The way the car sits is the way I picked it up...only thing I've done was change out the brake pedal (was an auto), replaced the coolant, adj the e-brake, & replaced some missing screws. DOES have heat, A/C, & power steering. Asking price is $3200 OBO...contact info is jcvalentin83@gmail.com
B18B1 cams
block guard
new oil pump (P72)
stock header
Stage 2 clutch
CHIPPED P28 ecu
i-Flik 15x6 wheels
GSR front brakes
sleeve coilovers
Lower rear tie bar
amber corners
EK side skirts
6k HIDs
EX cluster
pioneer CD player
GSR shift knob
BAD:
04 Neon SRT - (rebuild time)
03 B5.5 Passat Wagon 1.8T
Originally Posted by efficientkiller
none of this really matters at the end of the day...if you really want to know, the true answer is found in research, why post a ignorant thread & call it a debate? this is exactly why TR gets the critizism it does...
bump...need this gone within the next week or 2
