Wilwood Dynalite BBK/ H22 and K Valve Cover F/S!!!!
Old Dec 22, 2010 | 03:49 PM
EconoBox's Avatar
Four Door Mafia
Default Wilwood Dynalite BBK/ H22 and K Valve Cover F/S!!!!
I have for sale...
OEM H22 wrinkle black Valve cover - $100
OEM K Series Valve Cover OEM Silver - $100
Wilwood Dynalite Big Brake Kit
Kit Part number is 140-8695-DR
Included is everything necessary to install this kit. Crossdrilled and slotted rotors Dynalite 4 piston red calipers, all bolts and washers, pads and cotter pins.
I am also going to include a custom Russel stainless steel line kit for the front brakes. All adaptors and fittings required to install this kit will be included.
THIS KIT WAS USED FOR LESS THAN 3000 MILES. EVERYTHING IS IN MILDLY USED CONDITION AND READY TO USE. Rotors will need to be safety wired according to wilwood instructions. Since rotors and pads seat to each other the kit was uninstalled and everything is labeled specifically to match each side so that this is literally bolt on and go no seating required.
To see whats included and msrp visit JEGS click here
ASKING $500 for the brakes.
PM me if interested and I will respong ASAP
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
Old Dec 22, 2010 | 06:01 PM
Flipimp1's Avatar
Good deal on the BBK.
Old Dec 22, 2010 | 09:30 PM
Ls_[eg]hatch's Avatar
mowchowbrowncow
^ +2 bump
Old Dec 23, 2010 | 05:16 PM
EconoBox's Avatar
Four Door Mafia
Old Dec 23, 2010 | 05:24 PM
el_chamaa727's Avatar
good deal
Old Dec 23, 2010 | 05:48 PM
LShatch98's Avatar
i love making you mad <3
bump. wish i had cash. good price on the brakes
Proven Power for all your go fast needs
Old Dec 23, 2010 | 05:52 PM
BoostedRacerDad's Avatar
Pops
Can you run 15" wheels with this?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Dec 23, 2010 | 06:15 PM
LShatch98's Avatar
no^ according to the jegs link
Old Dec 23, 2010 | 07:41 PM
Pops
Just wondering if they are shaved.
JoKie TuNinG
StricKlyMT
727-510-6301
Old Dec 28, 2010 | 08:04 AM
EconoBox's Avatar
Four Door Mafia
These brakes do clear almost all common 15 inch wheels. I have used them with Rota Slipstreams, Buddy Club p1s, and Spun SPK-Gs without modifying the brakes at all. Wilwood's website says minimum 15 inch wheel and has a diagram to show what pattern wheel and offset will clear the caliper and rotor.
I have had no issues at all fitting these under 15s. On the Rota slipstreams they sit very close but no problems.
