FS**92 accord built for boost f22a1***$1200
NO TRADES... I have a 92 Accord with an F22a1 that was built and ran t3/t4 turbo which is longer on the car but is set up and ready if you choose. Will give more info on the internals of the motor later tonight. the tranny is a JDM MP1A off of an H22 witch is an auto transmision but is geared for for better top end. It runs strong and has never left me stranded. $1200 for the car only because the body is not perfect. any ? call steven at 863-226-7124
GOOD:
JDM MP1A AUTO TRANNY
Built F22A1
adjustable cam gear
lightweight crank pully
all new belts including timing belt
recently tuned up W/ NGK plugs and 7MM high heat wires
only used valvoline synthetic oil
new water pump
aluminum Radiator
new tires
4:1 2" header back exhaust
intake
Bad
the body needs some work
sittin on steelies
cracked windshield
GOOD:
Built F22A1
adjustable cam gear
new water pump
aluminum Radiator
new tires
intake
Bad
sittin on steelies
cracked windshield
