FS/FT Nissan 240SX S14.5
1995 Nissan 240sx S14.5
Ka24de - rebuilt 4200+ miles ago
S14 block
.5mm over bore
honed
decked
all coolant and oil passages cleaned
piston oil squirters
eagle ESP H-Beam rods
NPR pistons with file fit rings
ACL duraglide Main and rod bearings
ARP Main studs
Centerforce stage 2 clutch
Centerforce throwout bearing
New Megan Racing mounts/tranny
78,000 Mile tranny just Put it, Shifts strong
Turbo Ready!
s13 head
remanufactured
3 angle valve cut
new springs
new retainers
new cams
ARP head studs
Cometic MLS-5 head gasket (5 layer steel)
OEM timing chain set (all new guides, sprockets, and chains)
ported s13 intake manifold with internal butterflies removed
injen cold air intake
OBX race header
HKS Hi-Power exhaust 3"
Kyb GR-2 shocks
Tein springs
Tein control arms
Z32 brakes with slotted rotors
2006 350z anniversary wheels
S15 silvia front end with true silvia head lights
LSD rear diff
Tires Toyo 85% fronts/70% Backs
battery relocated to trunk
Cons: needs Alingment, Paint/Body Work, No A/C, Sometimes Belt screams,Tranny is startin to leak in the front, prob just gasket or front bearing goin bad, easy fix " ran short of money at the end" And Needs a Turbo!!!
extra info:
The car was built and fully machined by Performce
sales & service.The motor has just been broken in and tuned on Apexi SAFC and AEM
Wideband. 14.6 AFR cruising. GREAT GAS MILAGE. this setup
will easily last you another 150k miles with good care.
oil changed at 100, 300, 1000 miles. i have taken it on a
couple long trips about 150 miles orlando to tampa back and forth.
$6K OBO or trade
pics
813-407-1093 names Giovani text or call, mostly text, in school alot.
S14 block
.5mm over bore
honed
decked
ARP Main studs
Turbo Ready!
s13 head
remanufactured
3 angle valve cut
new springs
new retainers
new cams
ARP head studs
OBX race header
Kyb GR-2 shocks
Tein springs
Tein control arms
LSD rear diff
extra info:
$6K OBO or trade
pics
__________________813-407-1093 names Giovani text or call, mostly text, in school alot.
