FS: Shop Cleanup ALL O.B.O
Old Oct 20, 2010 | 06:43 AM
da92nv's Avatar
...let's blaze!
Talking FS: Shop Cleanup ALL O.B.O
B-Series A/C Compressor w/ Bracket & Tensioner Pulley (Believe Bracket was for B20)
19 Tooth Water Pump (Works Perfectly)
Various B-Series A/C Brackets (if you know what they belong to lmk lol)
LS Alternator Bracket Set
Shift Linkage (CRX/EF) I can take measurements if you like
P72 Power Steering pumps (Both work, 1 is missing the pulley)
Radiator Fans (No Plugs)
Integra/Civic Front Caliper Set w/ Stock lines (Work Perfectly)
DA/DB1 A/C Lines w/ Bracket
K20 Valve Cover (Rattle Canned Black)
SOHC VTEC Polished Valve Cover SOLD
SOHC VTEC Valve Cover
OBD0 VTEC Solenoid (Pressure Switch plug Broken but works)
LS Fuel Rails
DB2 front Sway Bar
DB2 Front X-Member w/ Radius Rods (Will fit DA/DB1 but cannot use stock frame brace)
DB1 Trunk
ALL ITEMS ARE BEST OFFER / TRADES WELCOME / ORLANDO AREA / WILLING TO SHIP / 407-267-7465 TEXT ONLY!
...TR's OldSkool DA Crew Member #00...
...TR's Oldskool DB Crew Member #02...
Old Oct 20, 2010 | 06:53 AM
1lowSi's Avatar
1LowSi is a white guy
two various Ac brackets look like D series
VOUCHES on TR: eda6, 1LowEG02, SUPERCHARGEDCIVIC, Seasicksean, HonkeyDong, Supercrx88, lzylst
VOUCHES on H-T(jdmh22eg2) :neophyte210, RhdRicheeee, russlavoilette,lzylst
Orlandoforums (ThatWhiteGuy) -- Anyone
I LIVE IN DAYTONA BEACH
Old Oct 20, 2010 | 07:00 AM
da92nv's Avatar
...let's blaze!
The only part that I know is that are both B-Series....I havent had a D-Series in the shop for a while...Sorry I should have specified! Thanx!
Old Oct 20, 2010 | 07:02 AM
1lowSi's Avatar
^ oh idk then i have not seen any B series like that only other one i have seen with center cut out like those are some H series
do they got ANY part numbers i can cross ref for u on system we have here
Old Oct 20, 2010 | 07:09 AM
da92nv's Avatar
...let's blaze!
top 2 are stamped PR3 & the Bottom one is stamped P30...could be LS, could be B16, could be obd1 GSR???
Old Oct 20, 2010 | 07:11 AM
1lowSi's Avatar
p30= b16
pr3= Ls
i dont think they are obd1 Gsr(b17) they had a diff set of numbers for them
Old Oct 20, 2010 | 07:15 AM
da92nv's Avatar
...let's blaze!
I have a full OBD1 B17 swap in the shop right now for a DB2 I am working on and its A/C comp bracket is labeled PR3. (frickin Honda...too many codes to confuse us all!)
Old Oct 20, 2010 | 07:19 AM
1lowSi's Avatar
^ thats strange i have had 2 b17's and they had some p30 and some other set of numbers i forgot
Old Oct 20, 2010 | 07:25 AM
da92nv's Avatar
...let's blaze!
frickin honda! lol This B17 is all original too so who knows! thanx for your help!
Old Oct 20, 2010 | 07:26 AM
1lowSi's Avatar
np
bumps for b17 love that motor
