What parts do you not trust buying used?
Old Jun 17, 2010 | 10:54 AM
chi town brat's Avatar
! Ne shab'rud'ni !
Default What parts do you not trust buying used?
So I am finally building an LS Vtec. I have wanted one ever since I drove Daves EG hatch some time ago in a galaxy far away.
Since - as my per usual - this build is on a budget and I've started looking for the parts needed.
As I look I started thinking about the parts I would not want to buy used.
For example, some say buying a slightly used valvetrain is okay but I don't agree.
What do you guys/girls say no to when it comes to used parts?
btw used water and oil pumps are a given. I'm thinking about the performance adders.
Old Jun 17, 2010 | 12:25 PM
sxysweed's Avatar
CRX.XXX
No used transmission, blocks, heads, or longblocks unless they come from a trusted source, with paperwork, and with a good history. That's just items that are too expensive the skimp on.
Old Jun 17, 2010 | 12:49 PM
YARO's Avatar
Smith & Wesson Protected.
I learned my lesson with transmissions. So I don't buy any moving shit of here (motor,trans,turbo,ect..) unless is somebody reputable or that I know. But I will try to avoid it regardless. If you can't inspect it internally you're taking a risk.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Jun 17, 2010 | 01:19 PM
opiumdaze's Avatar
wheels.. ive had my share of slightly bent wheels boughten and found out when balancing
Old Jun 17, 2010 | 02:53 PM
Alswizzo's Avatar
The Underdog!
This...
Old Jun 17, 2010 | 04:55 PM
chicacivic1217's Avatar
oh snap
We have bought a used transmission. Third and fourth gear we grinding so bad, they barely went in. So def. no used trannys unless we know the person.
DC(5)CREW MEMBER #30
Proven Power FTW
Originally Posted by racer_x
^you're a female, so your intrinsic fail level is higher than mine. Thus, I reason that if we both fail equally, you still fail harder.
Old Jun 17, 2010 | 05:50 PM
flatrex's Avatar
crx hatch sedan
Anything from the Honda/acura parts fs section on this site. To many scammers
Old Jun 17, 2010 | 06:16 PM
StreetBlitz's Avatar
B Tuned CRX
as for internals, i wouldn't EVER buy used. if on a budget, you can put together a very nice setup with OEM honda parts. which are way cheaper than aftermarket. with so many b series engines types out there, usdm/jdm the options are endless.
Old Jun 17, 2010 | 06:42 PM
FoxHondaRider's Avatar
Registered Hater
usually wear related items. Engine internals I am very hesitant about.
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old Jun 17, 2010 | 06:53 PM
SuburbanNoize's Avatar
Cold Ass Honky
Exactly, no used turbos, trans, swaps, blah blah blah. I would buy a bare block though, only if I was going to bore it.
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
