$40 and under sale. everything must go, moving out.
need all this gone out of my parents house asap. located in orlando. 407 722 1902 Jon
92-00 civic coupe/sedan exhaust $30
sohc hydro axles, one of the boots is broken $10
96-00 civic complete splash guard setup $20
92-95 civic coupe/hatch power mirrors $20
92-95 civic coupe/4dr rear mud guards $10
92-95 civic coupe rear seats $20
96-00 civic coolant reservoir with braided line $10
92-95 civic coupe/hatch corners $10 all
b-series vtec solenoid with skunk2 cap $40 firm
99-00 civic si rear end links $20
96-98 civic rear tail lights $20
96-00 civic drivers side power mirror $10
ls cast iron post mount $10
96-00 civic oem stock fuel filter with 3k on it i upgraded to an inline $20
b-series dip stick $5
96-00 civic steering column $20
96-00 civic aftermarket dark grey fogswitch $10
misc b-series lower engine braces
misc b-series brackets
96-00 a/c bracket $10
96-00 civic wiper setup with arms and windshield washer fluid tank $30
3" reinforced coupler and 3"-2.5" coupler
energy suspension rear mount inserts brand new $10
b-series oil squirters $20
gsr lost motion assemblys $30
gsr stock springs and reatainers. you can use the inners to put on your exhaust side so you can have dual valve springs on both sides like type r. $30
b-series upper timing belt cover $10
oil cap $5
99-00 power door harness $40
96-00 rear hatch latch $5
d-series throttle cable $5
jdm type r header bracket $20
96-00 hatch tail light harness $10
gsr injectors $20
oil cap $5
gsr injectors $20
Wish you were close...
TR "Old Skool EF" Member #124
EF-1991 Civic EX Hatchback W/Built D16 - SOLD!!!
EJ1-1993 Civic EX Coupe W/ B18 - SOLD!!!
EK-1998 Civic EX Coupe W/ Stock D16 -DD!!!
