F/s F/t 94 Integra ls
Old May 28, 2010 | 10:41 AM
Rorok's Avatar
Default F/s F/t 94 Integra ls
Im lookin for 3500 OBO Trades welcome
5 Speed. Rebuilt motor, right now its around 112000 miles on it, The dash was swapped with new gauges so the miles will be different. Its got a B18B1 motor in it.
Pros and Mods:
-Tein lowering springs
-Skunk 2 cams
-AEM Camgears
-Stage 2 clutch
-DC Header
-AEM Short Ram Intake
-Exhaust
-MSD Wires
-NGK Iridium IX plugs
-Working AC
-Painted valve cover
-Replace valve cover gasket and orings
-New timing belt and water pump
-New Brakes and Rotors (i have 2 used slotted front rotors ill throw in for free)
-New Distributor itself, and cap and rotor replaced too
-New wiper blades
-2 new back tires
-got better front tires on it
-Alignment and tie rods replaced
Cons:
-Needs a IAVC (idle air control valve) the idle tends to fluctuate a little bit. i know advance sells them new for 120, unless you know how to clean them or get one from a junkyard.
-Needs the blinker lights installed, i have them i just never had the time to install them or buy the bulbs
-Front CV Axles - can get em for about 40-60 bucks
Any questions just PM me on here.
94 Integra LS - DD/b20swap/Current Project DC Crew Member #53
Old May 28, 2010 | 12:22 PM
jdm92dx's Avatar
i got a 4 door with a mini me check my thread lmk
Old May 28, 2010 | 01:33 PM
Josh.'s Avatar
The Integra Guru!
Bump for my buddies old car
04' Crystal White Lexus IS300
04' Premium White Pearl RSX-S
Originally Posted by 94lsteg
Old May 28, 2010 | 02:12 PM
civic_ej8's Avatar
i got a 94 ex coupe with a jdm b16
Old May 28, 2010 | 02:40 PM
Rorok's Avatar
Thanks for the bump. +repd.
Old May 28, 2010 | 02:41 PM
Rorok's Avatar
PM'd
Old May 28, 2010 | 02:44 PM
Rorok's Avatar
Its a thought, ill see what else is out there and ill let you know.
Old May 28, 2010 | 03:39 PM
jdm92dx's Avatar
ight bro lmk bump
Old May 28, 2010 | 07:02 PM
Rorok's Avatar
bump, ill be getting the alignment and 2 front tires done 2morrow.
Old May 28, 2010 | 10:45 PM
vt_sol_ec's Avatar
I Give My .02 When Needed
Seen this car in person and is very clean. Bump for a nice Teg.
Nikon Owner
IG: @equippedphotography
FB: Equipped Photography
1994 Integra RS - Stock LS/SOLD
1994 Del Sol - Stock D16y8/TRADED
1990 CRX Si - SiR B16a/TRADED
1998 Integra GS - JDM B20b/TRADED
1994 Integra GSR - Tuned H22a/TRADED
1999 EK Coupe - Backburner
1995 JDM Front Integra - Project
2014 F-150 5.0L - DD
