Drop Engineering Extended Wheel Stud - 12 x 1.5, 76mm - Set of 16
Old May 19, 2010 | 08:12 AM
b2autodesigns's Avatar
Default Drop Engineering Extended Wheel Stud - 12 x 1.5, 76mm - Set of 16
Hello Guys,
Honda/Acura Drop Engineering Extended Wheel Stud - 12 x 1.5, 76mm - Set of 16
Drop Engineering Extended Wheel Studs are all specially forged from Steel Alloy 4140, a steel alloy characterized by its endurance. Using extended wheel studs permits drivers to run lower offset wheels on a vehicle. Longer wheel studs are essential when using wheel spacers to move a wheel further out. Drop Engineering extended wheel studs allow drivers to reduce friction or backspacing issues on their tires without cutting down on available threading.
Designed with performance in mind, Drop Engineering studs easily withstand the additional stresses produced by racing conditions, namely rapid acceleration and tight cornering. While factory studs are made just with the tires in mind, Drop Engineering studs have more available threading to ensure that even spaced out wheels are securely clamped to the axle. Designed to function with Drop Engineering lug nuts.
$72.60 shipped to you w/Florida sales tax. Takes 3-4 days
We also have Blue and Purple lug nuts to match:
Drop Engineering lug nuts are carefully crafted from AL7075-T6. T6 temper 7075 Aluminum is an aircraft quality alloy, boasting an impressive ultimate tensile strength of 74,000 - 78,000 psi (pound per square in) and minimum yield strength of 63,000 - 69,000 psi. This level of strength guarantees that the Drop lug nuts will hold up even under the most demanding racing conditions. Drop Engineering forges all of their lug nuts from AL7075 because it guarantees the greatest level of tolerance without any added weight.
Each lug nut is carefully crafted from an extruded aluminum billet. Drop Engineering utilizes CNC machinery to ensure the highest grade of precision quality during production. Stylish and durable, Drop Engineering lug nuts are an ideal upgrade for track or street drivers. Designed to function with Drop Engineering extended studs.
$96.00 shipped to you w/Florida sales tax. Takes 3-4 days to your door.
Blue finish:
Purple finish:
Please shared_pm me or call 813-787-4075 for pricing or any questions you might have.
Thanks
Charles
Visit us online www.b2autodesigns.com
Aim: b2autodesigns2 or B2AutoDesigns
cback@b2autodesigns.com
Face Book: B2 Auto Designs
813-787-4075
Old Jun 30, 2010 | 12:04 PM
Bump,
Thanks
Charles
813-787-4075
Old Oct 9, 2010 | 04:52 PM
bump,
Thanks
Charles
813-787-4075
