B2autodesigns offers Drop Engineering products!!! Really nice stuff
Hello Guys,
We are not selling Drop Engineering products.
Check out some of there stuff!!!
Drop Engine Mounts
Drop Engineering Engine Mounts are painstakingly assembled from 304 Stainless Steel, the industry standard in high quality stainless steel. Every mount from Drop Engineering comes equipped with rigid polyurethane bushings, tested at a durometer of 75, to more efficiently transfer power to the wheels. Vehicles outfitted with Drop Engineering Engine Mounts will see quicker engine response and easier shifting even at a higher RPM. Each mount is CNC plasma cut and hand TIG welded with the utmost attention to detail and accuracy. A Drop Engineering Engine Mount is an ideal upgrade for any driver looking for improved performance, but is also highly recommended when installing a new motor as a replacement for worn out factory mounts.
Engine Mount Features
• Sturdy stainless steel construction
• Quicker engine response
• Easier shifting
• Lifetime Warranty
Key Applications: ACCORD H22, CIVIC, CIVIC B SERIES, CIVIC D SERIES, CIVIC EP3, CRX D SERIES, ECLIPSE, EVOLUTION, INTEGRA, MUSTANG, RSX DC5, SRT-4, STI, WRX
94-01 Acura Mount kit:
Drop Race Bushings
Drop Engineering Billet Bushings are the ideal replacement to stock OEM rubber bushings. Drop Engineering Billet Bushings are precision machined and molded using Delrin or UHMW material. Replacing OEM bushings with top of the line Drop Engineering manufactured billet bushings will significantly reduce wheel hop and improve acceleration. Drop Engineering Billet Bushings will provide optimal performance for any vehicle.
Race Bushing Features
• Reduces wheel hop
• Self-lubricating
• Machined with Delrin or UHMW Polyethylene
• Lifetime Warranty
Key Applications: MUSTANG, RX7, RX8
Drop Accessories
Drop Engineering has a full line of accessories designed to function seamlessly with their race engine mounts and race bushing kits. Drop Engineering Extended Wheel Studs, Aluminum Lug Nuts, and Polyurethane Motor Mount Inserts are all made to handle high performance driving conditions. Drop Engineering Lug Nuts are constructed of AL7075-T6 that will hold up even under the most intense racing conditions. Drop Engineering Extended Wheel Studs provide drivers with more threading to ensure that even spaced out wheels are securely clamped to the axle despite additional pressure. Built with quality and style in mind, Drop Engineering Aluminum Lug Nuts and Polyurethane Motor Mount Inserts come in a range of colors, offering drivers a chance to upgrade their style as they increase performance.
Lug Nut & Wheel Stud Features
• Lug Nuts: 7075 T6 Aluminum
• Available Colors: Black, Blue, Gold, Purple, and Red
• Thread Size: M12 1.5
• Extended Wheel Studs: Steel Alloy 4140
• Thread Pitch: M12 x 1.5, 76mm
Polyurethane Insert Features
• Available Colors: Orange, Yellow, Black, Red, Grey, and Blue
• Made of 75A durometer polyurethane
• Injection molded (eliminates air bubbles)
• Resistant to water, oil, coolants and grease
• Reduces wheel hop and motor movement
• Prevents damage from excess torque
Check the link for listing of parts offered:
Performance Billet Engine & Motor Mount - Drop Engineering
Please call me for pricing or with any questions you might have.
Thanks
Charles
Drop Engine Mounts
• Easier shifting
• Lifetime Warranty
Drop Race Bushings
• Reduces wheel hop
• Self-lubricating
• Lifetime Warranty
Drop Accessories
Thanks
Charles
Visit us online www.b2autodesigns.com
Aim: b2autodesigns2 or B2AutoDesigns
cback@b2autodesigns.com
Face Book: B2 Auto Designs
813-787-4075
813-787-4075
bump,
Thanks
Charles
Thanks
Charles
813-787-4075
813-787-4075
