Go Wide!!!! Ichiba V1 and V2 wheel spacers. Great pricing!!!
Old Feb 10, 2010 | 02:03 AM
b2autodesigns's Avatar
Default Go Wide!!!! Ichiba V1 and V2 wheel spacers. Great pricing!!!
Hi Guys
B2 Auto Designs is offering Ichiba Spacer kits in two different verisons.
First is the Standard Spacer with longer studs.
Ichiba Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
All are Sold as one pair (2pcs) with 10pcs of longer studs.
Offered in
5mm, 10mm, 15mm, or 20mm Kits
The Second Verison come with the studs already in the Spacer, This kit would require you to take a look at the Wheels you have to make sure that the back pad of the wheel (where the lugs go through) have indentations next to it, allowing the left over factory stud to come through.
Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Ichiba offers lots of different applications. Check the link to check if
Check out the pricing on my website:
B2 Auto Designs
Please shared_pm me with any questions you might have.
Thanks
Charles
Visit us online www.b2autodesigns.com
Aim: b2autodesigns2 or B2AutoDesigns
cback@b2autodesigns.com
Face Book: B2 Auto Designs
813-787-4075
Old Oct 11, 2010 | 04:10 PM
Bump,
Thanks
Charles
813-787-4075
Old May 20, 2011 | 03:28 PM
Charles
813-787-4075
Old Sep 4, 2011 | 06:38 AM
Hit us up for spacers!! There are lots of applications from Honda to BMW.
Thanks
Charles
813-787-4075
Old Nov 2, 2011 | 07:17 AM
Charles
813-787-4075
