Aftermarket D-series Parts
Old Jan 21, 2010 | 05:37 AM
stylnjj's Avatar
My eBay>> Nthefastlane
Talking Aftermarket D-series Parts
-Eagle rods MINT-$175
-Greddy cast Iron Turbo t25/t28 manifold no wastedate flange..Already tapped for EGT-$150
-Stage 4 F1 racing clutch 2,600k on it ..pressure plate,Flywheel "stock" re-surfaced,throwout bearring all the arp bolts for flywheel and pressure plate, 6 puck sprung clutch-$225
-Race OIL PUMP ported shimming and polished 20psi @Idle 80psi @7k come with oil suction scoop also-$100
-D16Y8 head ..Aem adjustable cam gear..valve cover, comes with intake manny throttelbody..just been resurfaced..had little detonation..valves are fine ringland crumbeld in little pieces nicked where the piston meets the head on 1 cylinder no biggie..NEW resurface job..new valve guides all new valve seals Ultra sonic cleaned-$500
-D16y8 Ductile Iron Sleeved Block & posted 75.5mm bore jst paid $1,400 asking $700 sleves are "Mint"
-Brand "NEW" T3 to T25/T28 flange adapter-$30
-Gates Racing Timming Belt Only 2,600 miles on it $40
-ARP HEAD BOLTS 6 months old $80
-Water pump only 2,600 miles $35
-Set of D16y8 pistons and rod's Excellent shape-$100
-D16y8 5spd Tranny "Just rebuilt,New input shaft bearring"NO GRINDS!-$350
I'm sure theres more Call/Text Jeremy@ 941-204-5751 any time!
