FS: BMW 325is E36 - Drift
Old Jan 16, 2010 | 07:46 PM
SRpower20's Avatar
Default FS: BMW 325is E36 - Drift
NO TRADES
Miles: 164xxx
Price: SOLD SOLD SOLD
Title Status: Rebuilt
Contact: jboldissar at gmail.com
Old Jan 17, 2010 | 12:38 AM
Signal7cbr!'s Avatar
hates change
now this is how a for sale thread should be...
bump to you sir
Originally Posted by b16sleeper
don't worry...if i see a white guy with an afro...i'll yell crackhead and watch the cops tackle you before you touch me..
Old Jan 17, 2010 | 04:52 AM
marktopia's Avatar
TR Balla Donor Supreme
hell ya. i havent seen a fs thread this presentable. bump for you and clean car with lots of info.
Old Jan 17, 2010 | 05:29 PM
SRpower20's Avatar
Some more questions I have been receiving I would like to share.
great car, I am interested in buying it. how are the tires? and describe the transmission trouble a little better.
all 4 tires 225/45/15 (kumho ecsta) have 85%+ tread left and are less than 6 months old.
in regards to the transmission. here is information regarding it on BF (bimmerforums.com) E36 "sticky" shift lever remedy?? - Bimmerforums - The Ultimate BMW Forum .
quote
"Basically, there is a spring in your transmission that pushes on a pin that pushes on your shifter to make it return to the center from 5th gear. This pin sits in a bushing that has some sort of (teflon?) coating on it. The original coating was defective, and would absorb oil and expand slightly over very long periods of time, causing the pin to get stuck in the bushing. To fix it, you have to remove the old bushing and replace it with a new one with a different coating on it. Unfortunately, this requires removing the transmission. Even if you don't happen to want to do that just to fix this problem, you may want to order the parts anyway, so you have them the next time you do have to pull the transmission for some reason (perhaps to replace the clutch or something).
BMW offers a repair kit for this ... Part Number 23117542726
This kit includes a new bushing, a cover lid (available separately as 23311224825), and a lock ring (available separately as 23317531374).
Most people complain about problems with 5th gear, but technically, reverse is also affected, so as long as you're going through all the trouble, you should probably order two of the kits, and replace the bushings for both 5th and reverse.
exhaust video
YouTube - exhaust e36
Old Jan 21, 2010 | 03:14 PM
SRpower20's Avatar
pending sale. a pretty confident buyer for this saturday!
