1999 VW JETTA 2.0 5spd 175k $2500 Central FL
Old Jan 15, 2010 | 12:09 PM
flatwhiteheap's Avatar
Default 1999 VW JETTA 2.0 5spd 175k $2500 Central FL
FOR SALE:
1999 MK3 JETTA
2.0 5speed
175K
ABOUT THE CAR:
-Has COLD A/C
-Runs Great
-Oil Changes done every 3,000 miles
-Raceland Coilovers with heavy duty strut mounts/new bearings with just about 1000 miles on them
-Shaved Trunk
-Silver Faced Cluster
-Interior was "Beaver" and the only things that remain that color are the cloth seats and rear door cards, visors and oh shit handles.....Since owning, black carpet, black dash and all dash pieces, black center console w/ early euro rear console, black rear deck were swapped in and all pillar pieces painted black
-Front Windows converted to crank and rears are still power but do not work(regs are bad)
-Front Bumper Shaved, but could use a bit of fine finishing work
ALL THINGS HERE HAVE BEEN DONE/REPLACED IN LAST 8-10k MILES:
-Recent Tune Up Including (timing belt w/tensioner, coolant flush with OEM fluids, cap and rotor, plugs and wires, thermostat, water pump w/ housing, all drive belts)--ALL WORK WAS DONE AT FULL THROTTLE, have paperwork
-Since Tune Up car gets roughly 380-420 miles to a tank(thats with half and half city/highway)
-K&N Drop in filter
-All shift linkage bushings replaced
-Front Lower Poly Motor Mount
-Driver & Passenger Axles Replaced
-R&L Ball Joints
-R&L Tie Rod Ends
-Rear Wheel Bearings
-Rear Shoes Replaced
-Front Pads & Rotors
WHATS WRONG:
-CEL is on due to emissions crap being removed...has no effect on the way the car runs or anything...its florida so there is no need for emissions
-needs a transmission mount
-rear regs don't work
-exhaust is stock but muffler doesnt have a tip on it, not my doing, bought it like that...sounds kinda throaty
-transmission was replaced in may and the new transmission has about 140k on it and reverse is noisy but doesn't pop out and works fine, all other gears have no issues what so ever
-has 4 steelies with random stock tires
-car was forest green, but was spray painted white and is starting to show some signs of needing a respray
-headliner was done purple plaid but needs to be redone
TAILS ARE NOT INCLUDED (WILL HAVE REGULAR AMBER/RED TAILS)
STEERING WHEEL AND HUB NOT INCLUDED (WILL HAVE SOME SORT OF STOCK OEM WHEEL)
RADIO WILL BE REMOVED AND WILL HAVE JUST A BLOCK OFF PLATE
EURO SWITCH WILL BE SWAPPED FOR AN N/A SWITCH
IT HAS MIRROR DELETES ON NOW BUT WILL BE SOLD W/ MIRRORS
IF YOU HAVE ANY QUESTIONS FEEL FREE TO EMAIL ME AT FLATWHITEHEAP@HOTMAIL.COM OR GIVE ME A CALL AT 407-968-2485
TITLE IN HAND
Old Jan 15, 2010 | 06:12 PM
pr941's Avatar
M.P. Racing
b u m p...... if u decide to keep it i have a full bodykit for it in white. lmk 941-592-3919 miguel
*M. P. Racing*
