f.s or f.t chipped vtec computer
Old Oct 19, 2009 | 03:58 PM
honda freak's Avatar
Default f.s or f.t chipped vtec computer
This is a used computer is a P06 ECU converted to P28 / P72 / P30 specifications.. It can run your VTEC motor just like a P28, P72, or P30 ECU. It can also run non-vtec motors just like a P06, PR4 or P75. I tested it in a 1993 Honda Civic and it works perfect.
1. ZIF(zero insertion force) socket
2. An on/off Jumper switch used to change from the stock OEM program to the chip program
3. A datalogging header used for tuning.
This computer can work for the following manual cars:
1. ODB1 (92, 93, 94, 95) VTEC and non-vtec Honda Civic’s.
2. ODB1 (92, 93, 94, 95) VTEC and non-vtec Acura Integra’s.
3. ODB1 (92, 93, 94, 95) VTEC and non-vtec Honda Preludes.
4. ODB1 (92, 93, 94, 95) VTEC and non-vtec Honda Accords.
5. Newer and older VTEC and non-vtec Civic's, Integra's, and Preludes can work with a conversion harness.
This computer can work for the following automatic cars:
2. ODB1 (94, 95) VTEC and non-vtec Acura Integra's.
With this ECU you can properly do fuel management for a turbo or naturally aspired car. It will work perfect for your VTEC swap. If you are planning a VTEC engine swap in the future it will work as chipped non-vtec ECU until you do you swap and then it can be setup as a chipped VTEC ECU. You can get rid of the speed limiter, change redline, change the rpm of VTEC engagement, create a two step launch control, make your check engine light work as a shift light and many other things using Uberdata or Crome software that is free which will be included on a DVD as well as the bin file that is on your chip. This ECU will also work with other tuning programs like Neptune, Ectune, and Hondata.
This is a perfect way to tune your car correctly, whether you have a few performance upgrades or a turbo kit. The nice thing about this ECU is that it is ready to go. No soldering needed, just pull the lever, pop out the chip, change the settings you want using a chip burner and pop it back in with the new program. Also with the jumper switch, just switch it and you will be running a stock P06 (Civic CX, DX, LX) program.
im looking for price offers.. i got a 1992 integra so if you got parts n stuff i would consider trades.. text at 321 746 2351 or pm me thanks
