FS: Various 94 up integra parts.. Very Cheap.
Old Aug 31, 2009 | 07:27 PM
Rapido76's Avatar
Default FS: Various 94 up integra parts.. Very Cheap.
Everything is off a 94 up 2dr GSR integra. If you need pictures of anything pm me and i will post. I tried to be specific. Please bump if you view! you will be repp'd.
LS Cluster -
5 Speed** Reads 150k - $50
Passenger Side inside of door power lock mechanism - The door lock part with electrical part attached to it for power door locks. - $20
Front Windsheld Trim
Hard to find and in perfect condition. $20 for one $40 for both!
94-96 Rear View mirrors - They are in mint condition, Dark Green. $30 for both.
Stock hydrolic Shocks for rear hatch in perfect working order. $40 for pair.
OEM Integra CD Player with Code works fine, includes the attached pocket under it. $30
DC2 GSR OEM Wing - have two in great condition, one is factory dark green, and the other needs to be painted. - $30 for green one and $20 for the other one.
Tan Dashboard in mint condition w/ airbag $30
Black Dashboard with passenger air bag
in excellent condition. $60
Antenna with motor in good condition. $50
Entire sunroof assembly In excellent condition sunroof works perfectly and opens and closes fast everytime. $60
A/C components under dash In perfect working order. $30
Rear black plastic piece that covers taillights INSIDE the car. Good condition. $20
Side Black Plastics not in excellent condition. the drivers side has a small chunk missing by the hole for the struts in the trunk. $20 for both.
Fuse Box under the Dash with fuses still in it. $30
Fuse Box in Engine Bay where the ground comes out for the car. and it has ecu fuse and relays.. $20
Complete Cruise control... Box with line which connects to pedal, switch and whatever else is needed with the cruise control.. $30
Kick Panels.... In good condition.(have a black pair/and a tan pair) $20 a pair
Under dash OBD1 GSR wiring harness In perfect working order. $60
DSM Eclipse/talon/laser 4g63 Turbo Manifold... Stock manifold. had a small crack at the top and was welded. Has been used for a almost a year after it was repaired and no leaks or problem, was taken off because an aftermarket one was put on. Has a little rust on it, can be easily sanded off, does not affect function. $20
Old Sep 1, 2009 | 01:06 PM
Rapido76's Avatar
up
Old Sep 3, 2009 | 02:42 PM
Rapido76's Avatar
ttt Bump if you view!
Old Sep 3, 2009 | 03:42 PM
killerSRT's Avatar
Registered Abuser
What color is the hatch?
Old Sep 6, 2009 | 09:57 PM
Rapido76's Avatar
the hatch is milano red. the paint is a little faded. no dents or chips anywhere on it.
Old Sep 7, 2009 | 07:40 AM
Jose.mercado1955's Avatar
do you alSo have AC condenser, head lights, or a windshield?
prices?
pm back please
Old Sep 7, 2009 | 07:57 AM
hkshaitian's Avatar
hey the gsr harness is the interior harness?
Old Sep 9, 2009 | 12:51 PM
Rapido76's Avatar
pms sent. up!
Old Sep 9, 2009 | 12:56 PM
IslanDC5's Avatar
V.I. Finest
bumpity
Old Sep 9, 2009 | 01:22 PM
Rapido76's Avatar
appreciate it! repp'd
