parts for cheap and free
Old Aug 12, 2009 | 06:17 PM
kabuki mono kid's Avatar
Default parts for cheap and free
90-93 acura integra parts
4 tokicko shocks and stuts with lowering springs. i bought these and one had a bent fork and upon inspection come to find out it was blown. i believe the other 3 are good but am not 100% i havent installed them bc i have been busy. i paid 150 but will sell them for 75 obo. all you need is one good shock to have a complete kit
jdm 1 piece headlights need a little work one has a small crack 100 obo
driver side headlight and bracket broken adjusted but is an easy fix 5 obo
92 bumper lights/turn signals both in good shape 5 obo
turn signal/wiper arm. part that goes behind steering wheel 5 obo
both horns 5 obo
clutch pedal 5 obo
little cup holder deals that go by cargo cover 5 obo
dead pedal 5 obo
water neck 5 obo
upper rad hose 5 obo
front plastic that goes by your foot on pass side 5 obo
yellow fog lights in good cond. paints a little faded 10 obo
lower steering wheel cover 5 obo
seat belt control unit 5 obo
trunk and gas lever 5 obo
under hood fuse panel 5 obo
upper steering wheel cover 5 obo
clock 5 obo
throttle cable 5 obo
wiper arms painted all black 5 for both
denso map sensor 5 obo
complete interior wiring harness from a 90 da. obdo wiring i didnt see any cut plugs 25 obo
gas cap 5 obo
stock rad with cap 20 obo
ac condensor 20 obo
ecu cover 5 obo
resistor box 5 obo
under dash fuse box full of fuses 5 obo
under dash wiring 5 obo
turn signal brackets 5 for both
rear defogger switch 5 obo
hazzard switch 5 obo
fog light switch 5 obo
cruise control unit 5 obo
crx gauge cluster 20 obo
cluster cover 5 obo
3 motegi mr7 rims. all are a little rough. 2 are gunmetal and one is silver one has bad gashes on the inside of the rim from the lug nuts coming off and the rim grinding on the brake rotor. all 3 for 40 obo
dist cap by msd for honda civic 1.5/6l 92-97 part number 8292. appears to be complete but not 100% sure. brand new 10 obo
optima red top battery. its been sitting for a while so its dead and im not sure if it works but you may be able to return it and get a credit or something. 10 obo
that looks like about all of it for now. i will meet if your in the tnc or carrollwood area. no i will not drive 20 min for a 5 dollar part. if you need multiple parts i will give it to you for cheap. what ever doesnt sell in about a week or so is getting thrown in our compactor at our apt. i can be reached at 8138411345 i can text easier than call since im at work alot
http://s869.photobucket.com/albums/ab254/kabukimonokid/
Old Aug 12, 2009 | 06:22 PM
steezyteg's Avatar
2.2L vtakk
tokico struts im in same situtation will you sell me one rear for a good price lmk
Old Aug 14, 2009 | 04:43 PM
ttt need all this gone asap
