For Sale/WTB TRuck Strictly TRuck related for sale/WTB
1998 S10 LS1 Professionally Built Tons of Pictures MUST SELL
Old 04-03-2009, 06:01 PM
Senior Member
CobraSpdRH's Avatar
Default 1998 S10 LS1 Professionally Built Tons of Pictures MUST SELL
Engine:
5.3 block bored to 346 ci
stock ls1 pistons, rods, and crank
arp rod bolts
stock 5.3 heads ported and polished also milled to increase compression
compression ratio 10.8 : 1
rollmaster double roller timing chain
02 ZO6 camshaft and valvesprings cam specs 204 int 218 exh .551 lift intake and exhaust
Manley hardened pushrods
GMPP single plane carbureted intake manifold
Holley performance 650cfm mech secondary carb with choke deleted
MSD 6010 programmable ignition box with 2 step and nitrous retard capability
Sanderson 1 5/8 shorty headers with SCE copper gaskets
LS2 corvette oil pan, windage tray, pickup, and dipstick
Trans:
Lokar flexible dipstick tube
Edge racing converters custom street strip converter 3100-3300 stall 2.2 str ratio set up with large bore pump to increase highway coupling
TH-400 transmission street strip prepped for up to 750 hp
Trans-go level 3 shift kit
Adjustable shift modulator
Kolene steels and Alto red clutches with extra clutches and steels added to intermediate and direct packs
32 element roller sprag and direct drum from 4l80 trans
electric speedo conversion
direct clutch upgraded snap ring from 727 torqueflight trans
dircet clutches priority fed by valvebody
deep truck aluminum pan for added cooling
LPW trans cooler largest availible used on r/v's and busses
overhauled and shimmed performance front pump
all new case bushings and torrington or bronze bushings substituted wherever possible
B&M megashifter
Full manual shifts into any gear at any time but will shift automatically in D position
low throttle input first gear skip mod (will help with traction on wet days trans will start out in 2nd
Suspension
Cal Trac traction bars
QA1 fully adjustable coil-ver front suspension
Lowered rear leaf springs with Nitro drop shocks (no blocks)
Larger diameter sway bars
REAL Torque Thrust II's 17 x 9.5, brand new tires out back
Battery mounted in truck bed for increased traction
Interior
Upgraded Sony speakers all around (replaced stock)
Sony headunit
Fully custom AutoMeter gauge display (looks amazing)
Brand new carpet included with sale (didn't trim it for the new shifter yet, also waiting to put in some upgraded seats)
Everything works like stock, it just has an LS1 :nod:
Rear End
8.5 inch swapped in w/ drum brakes, 3.73 gears and PowerTrax locker (just installed ~200-300 miles ago)
Braided brake lines (all)
Upgraded drilled/slotted disc breaks with Caprice calipers (huge)
This truck was built by a professional mechanic of over 10 years, easily over $16,000 and hundreds of hours invested to do it the right way, I would drive this thing anywhere. The body is in good shape but it could a spray-on bedliner. Truck doesn't currently have a/c but we left everything there and all you would need is a high-mount compressor. Also, I think a wire is pinched for the fuel gauge b/c it isn't currently reading I just haven't taken the bed off to get into it. That is all this thing needs, just being honest.
I need 4 doors and I don't have any room in the garage so I unfortunately have to sell. I am, however, a realist, and know I can never get back what I put in to it. Looking to get somewhere in the neighborhood of $7,000. The engine, trans and rear-end along are worth close to that, plus you get a free truck!
Truck is located in Clearwater FL and can be seen anytime. If you come see and drive the truck you will not be disappointed. PM me with any questions. On to the good stuff:
Old 04-03-2009, 07:58 PM
UF Mech/Aero Eng
skunk2racing97's Avatar
clean. bump 4 u.
Old 04-03-2009, 07:59 PM
banzaii's Avatar
Nice whip....if i had the cash id get that thing off u in a heartbeat....g/l with sale
Old 04-04-2009, 04:22 AM
Senior Member
CobraSpdRH's Avatar
Originally Posted by skunk2racing97
clean. bump 4 u.
Thanks, just bought a WJ so I'm lookin forward to doing some wheelin.
Old 04-05-2009, 04:54 PM
Senior Member
CobraSpdRH's Avatar
Video posted!
Old 04-05-2009, 05:10 PM
Senior Member
CobraSpdRH's Avatar
FYI the audio sounds kinda shitty for some reason (I used one of those Flip Mino's) but if you listen aroun 2:50 in you get the exhaust sound. Hopefully the quality gets better but I can always post a new one if it doesn't
Old 04-06-2009, 02:27 PM
You'll need it!!!
launch's Avatar
Nice truck. bump for you.
Launch It Like It's Unbreakable!!!
Old 04-23-2009, 07:28 PM
You'll need it!!!
launch's Avatar
This was a great truck. did it sell?
Old 04-24-2009, 07:01 PM
Senior Member
CobraSpdRH's Avatar
Yup, it is on its way to Kansas, bought sight unseen. Sad to see it go.
