Eg/ek/dc/parts For 4 Sale~~~
Moroso 5.5 Qt Oil Pan And Pick Up (brand New) $300
Ls Stock Header $40
Ls Teast Pipe With O2 Bong $60
Gsr Rack And Pinion With Tier Rod End $100
Gsr Subframe $100
Ls Stock Axle Back $50
Eg/ Or Dc Innovative (red) Timing & Rear Subframe Mount $125
2000 Ls Distributor $150
95 Integra A/c Controls $60
99 Si Intake Mani $75
95 Ls Intake Manifold $40
00 Ls Intake Manifold $40
Ls T/b With Sensors $80
Gsr T/b With Sensors $100
Single Cam T/b $40
Ls Cloth Tan Front Seats $40
Eg/dc Skunk 2 Rear Lower Tie Bar $50
B20 Valve Cover $80
95 Ls Valve Cover Powdercoated Red $100
B16 Valve Cover $60
B16 Cam Gears $25
99 Si Intake Manifold $60
99 Si Block/oil Pump/water Pump/tensioer/water Tube $150
99 Si Oil Pan And Pick Up $80
99 Si Crank Shaft $80
99 Si Pistons And Rods $60
Or Take It All With A Head(missing Parts)for $400
Ls Stock Header $40
Gsr Subframe $100
Single Cam T/b $40
B20 Valve Cover $80
B16 Valve Cover $60
B16 Cam Gears $25
is the moroso taped or anythng like that and also is it for ls... and can you get me a pic of it... pm me for email or just post in pm thanks...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
hp~5!! trq-4!!
doing work!!!!!!
Wow......!
Cheap Honda Parts! TypeR, civic, AEM, eagle, and more. W/pics! Check it out
Click for > J-PEZ_Motorsports -Shop Forum
___________________________
Tranceologist Powder Coating
Will post pics of the tie bar
Yes the oil pan is tapped for return lines and etc /has like 3 threaded fittings and baffles so the motor does'nt starve for oil and great for boost with the extra qt!!!
