b series turbo kit part out...
Old Jan 21, 2009 | 04:22 AM
KJ's Avatar
KJ
bored at work
Default b series turbo kit part out...
This b series turbo kit is the one shown in my build thread here with a few changes.
https://www.tamparacing.com/forums/h...ar-myslef.html Link isn't working now for some reason but you can go to my phot albums on this site and see the pics of the motor and turbo setup.
Turbo kit is A/C compatible and will support over 500whp. Turbo and blowoff valve were bought new from Alpha and have been installed but not ran yet, he can vouch for this. All other components are in great condition and have less than 4000 miles. Turbo kit with 57 trim turbo (smaller) made 400whp on pump gas.
-Turbo is a new Precision SC6152E, 5 bolt turbine housing 0.63 AR, with an E compressor housing. Can support upwards of 500whp. Turbo has zero miles but the turbine housing does have surface rust from being installed. Motor has not even been started since turbo was installed. $700obo
-Ceramic coated UGR cast A/C friendly exhaust manifold. This is a great exhaust manifold, boost control is rock solid with the centrally located wastegate port. 3" stainless steel downpipe w/ o2 bung. 1 3/4" stainless steel dump tube. 3" aluminum turbo intake pipe w/ K&N filter. This setup needs a t3/t4 with a five bolt turbine housing to fit correctly. Setup shown in pics is with an "e" compressor housing, not sure if an "S" housing will fit. $500 obo.
-Genuine TIAL 38mm wastegate. I believe it has a 9 psi spring. $150obo
-Genuine Tial 50mm blow off valve, new, installed but never run. $175obo
-All aluminum charge pipe, fits eg chassis and should fit DC as well, not sure on others. Flanged for Tial BOV. All pipes are bear rolled and include couplers and T-bolt clamps. Piping was designed to clear traction bars. $150obo. Piping may need modifications if not used with the kit above.
-Yonaka series 10 intercooler. $100obo
-Fast-turbo vacuum manifold. $10
-Precision 880 cc injectors (used)- SOLD
-Neptune RTP engine management installed in p72 ecu - SOLD
-GM 3 bar map sensor w/ pig tail - SOLD
-Knockoff greddy type RS blow off valve, used with 6" piece of 2.5" aluminum pipe with welded on flange. $25.
I'm actually parting the whole car out so there will be more to come including the motor, tranny, chassis, ect...
Old Jan 21, 2009 | 04:43 AM
amendoza's Avatar
Pm Me Your Number For The 3 Bar Map Sensor....
Old Jan 21, 2009 | 08:54 AM
KJ's Avatar
KJ
bored at work
Injectors and 3 bar have been spoken for. TTT
Old Jan 21, 2009 | 12:05 PM
KJ's Avatar
KJ
bored at work
Old Jan 22, 2009 | 04:46 AM
KJ's Avatar
KJ
bored at work
Old Jan 22, 2009 | 06:59 AM
KJ's Avatar
KJ
bored at work
Ttt
Old Jan 22, 2009 | 07:15 AM
tranceologist's Avatar
TR Shop Mod
damn dude that build looked sick . sux it wont b finished . gl man !
Old Jan 22, 2009 | 07:39 AM
KJ's Avatar
KJ
bored at work
It was finished and ran for a while. Took it apart for a turbo upgrade and change a couple of things and just never got motivated to finish. Now I'm just not into it and the car will just keep on sitting. If I ever do another car it will probably be an all motor car or a road race/autocross BMW. Turbo is too easy, lol.
Old Jan 22, 2009 | 07:43 AM
TR Shop Mod
o ok. thing was hella clean wen i saw it. prestine !!!
Old Jan 22, 2009 | 12:19 PM
KJ's Avatar
KJ
bored at work
