**CHEAP**Fresh JDM b16a longblock ACL,CTR,ARP,JE,ITR,BALANCED**PICS**
JDM B16a block bored .020"(.5mm) (Cedric @ Modern Performance did ALL machine work)
CTR oversized pistons .020"(.5mm)
JE piston rings file fit to .010(top) .012(bottom)
ARP rod bolts
ACL rod, main, and thrust bearings (with oil clearances checked)
Complete rotating assembly balanced by Cedric @ Modern Performance(crank pulley and flywheel included while balancing)
ITR oil pump
Block was also decked .010" for higher compression
Complete assembly is freshly built and has 0 miles(never even had the head installed)
$450obo
Rebuilt 1st gen B16a head
Freshly surfaced @ Modern Performance
New valve seals
Fresh valve job
B16a cams and b16a intake manifold included
0 miles since rebuild, never even mounted on a block yet
$450obo
Call me with offers @ (727)415-5363 or email me @ moe.digzz@gmail.com
Thanks for your interest
-Pete
ARP rod bolts
ITR oil pump
$450obo
New valve seals
Fresh valve job
$450obo
-Pete
